Old 01-05-2020, 11:20 PM   #1
Pd1620   Pd1620 is offline
Pipes glowing red common on these bikes?
Trying to get my Carb issues under control on the RFZ 125. I installed a VM22 style carb. Bike still idles high, I want to let it run and see if it drops after warming up, but the pipe gets glowing red hot after about 20 seconds. I read in a comment that that was normal, but I’ve never had that happen on any of my Jap bikes. So I’m assuming this is a lean condition. I contacted Apollo and they recommend I buy their VM24, wtf?
Old 01-06-2020, 06:48 PM   #2
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Any chance you can post a picture of the spark plug tip, it does sound like a very lean condition. Lean enough for engine damage if you were to run it hard. Most likely you’ll need a rejetting of the carb. This isn’t hard to do.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 01-07-2020, 04:04 PM   #3
pete   pete is offline
pete's Avatar
if the bike has a stainless exhaust and is sitting with the motor running the pipe can start to glow..thin stainless heats up very easly and with no air flow to help cool it...
but check to see if it is running lean..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 01-09-2020, 09:27 PM   #4
Here is the plug, let me know what you think.
Just a heads up I went ahead and ordered the VM24 direct from Apollo motors. It idles better, but still has the glowing pipe issue, and is still running rough.
Old 01-09-2020, 09:29 PM   #5
Plug
File Type: jpg 16FE7DB5-27DE-459B-A473-A0D7B6EC43AC.jpg (11.8 KB, 713 views)
File Type: jpg E11E7FA8-F764-44FC-A890-5D48727B00D5.jpg (12.0 KB, 717 views)
File Type: jpg 5BC84500-BE67-4DF9-9653-395F59F09620.jpg (12.1 KB, 713 views)
Old 01-09-2020, 10:30 PM   #6
Merlin   Merlin is offline
Could we see the plug straight on from the spark end?
Bashan Blaze
Old 01-10-2020, 01:23 AM   #7
Looking at the ground strap on the spark plug it does seem to be running a little lean. I would get the exhaust on my DR650 to glow red when I would fill up with 100LL AvGas out at my local airport. A picture of the spark plug head-on will help read the plug a little better. PD, what elevation are you at? If you're over about 2,500' ASL, you're likely going to have to go up a size on your pilot and main jets in the carb. If you determine that you are running lean, then a set of jet drills from Amazon might be a good investment for you. The only down side to drilling jets is that it's impossible to go back down in size. I think that VM24 uses Mikuni jets. Thanks to the marvel of internet capitalism, Amazon has jet kits for those, too. You can just buy the kit with an assortment of jets and spend an afternoon tuning. The collective wisdom of the forum should have you fixed up in no time.
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 01-10-2020, 08:50 AM   #8
I'm seeing the same thing as Emerikol. The high idle alone will make the pipe glow. What pilot jet is in the new carb? Is it the same as the stock carb or smaller. Have you adjusted the idle mixture yet? I would lower the idle to about 1500 rpms and adjust the idle mixture first.
2004 Honda ST 1300
Old 01-11-2020, 07:43 PM   #9
Here are more plug pics.
File Type: jpg F2D1DBF3-1312-4235-80AD-B21A04D84DD1.jpg (13.1 KB, 672 views)
File Type: jpg 86698C7C-DA3A-4D80-8C53-64445F2DCC29.jpg (12.7 KB, 634 views)
File Type: jpg FD3D6691-F3B5-4278-AA0D-CE51FC4C4EFE.jpg (13.1 KB, 632 views)
Old 01-11-2020, 08:57 PM   #10
Yeah, that grey ash on the end of the ground strap (the bit that goes over the top of the electrode) indicates that you're running very lean. I would start by dialing in the idle timing and setting the valves, and then go up at least one jet size on the carb. When you take the jet out, there will be a number stamped into the face. That's your jet size. You can use that as a base point to start your tuning adventures. When you order new jets, you should probably order an adjustable needle, too. Here's a really good write-up on how to tune the carburetor:
https://www.sscycle.com/tech-info/in...rb-quick-guide
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
pipes glowing carb issues
