Old 12-10-2019, 05:02 PM   #1
ikeus685   ikeus685 is offline
Send a message via Yahoo to ikeus685
Rear brake wheel HELP!!
I am real good at taking things apart. It's the flip side that's a problem.
Zero miles on My new Vader BD 125-10. I have take on and replace the stock tires with Shinko knobbies. Front tire went back on no problemo..Rear has been a test to the amount of frustration I can handle at a time.
Anyone who has dealt with this problem PLEASE chime in!! Left side of the wheel-cush drive, axle mounting through left side. No problem its that damn caliper and I can't for the life of me figure out how to get the opening between
the two pads to align and allow the disc to slide between
Old 12-10-2019, 07:52 PM   #2
Progress?
Should I bleed out more fluid so these stay open.. If; These stay like this I can mount but; Still not happy with how close the cast structure is on the right side
Replaced the fuel lines and removed the side panels to get at the fuel line and check out how the air filter is.
Old 12-11-2019, 01:36 AM   #3
pete   pete is offline
pete's Avatar
put a screw driver between the pads and spread them open...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-11-2019, 10:29 AM   #4
Thanks
1st thing I done then, compressed thepiston. , cracked open the bleeder. compressed the forward brass (???) bolt.
Old 12-11-2019, 10:31 AM   #5
Forward brass(??) bolt
This view is lookin down from on top.
Old 12-11-2019, 10:38 AM   #6
counting up 3 pix is where I am now. If no other advice comes up .. I will crack the bleeder valve again and try again…..
Old 12-12-2019, 08:36 PM   #7
NzBrakelathes's Avatar
You have an air lock in the slide pin? pushes caliper out etc - should slide back easily or remove some excess grease from it to stop it air locking and pushing out
Old 12-12-2019, 09:06 PM   #8
pin sliders
No: As most products from China.. May be assembled (and shiny) but was dry and needed light greasing and working the slider back and forth a bit. Also bled about 2" From the brake reservoir as seen though the see thru fuel line. No noticeable drop in the reservoir. Thanks for your response!!
