Old 12-10-2019, 04:06 AM   #1
achu007   achu007 is offline
Doh! Asiawing xz250rr race cam
Hi does anybody know any race cams that goes into asiawing xz250rr/ asiawing nc250. I am upgrading the carb,exhaust,cdi and much more and looking into swapping the head as well but dont know which one. And does the crf250x plastic fits on asiawing nc250? If yes which year honda plastic. Thank you
Old 12-10-2019, 09:53 AM   #2
NzBrakelathes's Avatar
Nothing for these - I sell NC250 stuff and theres nothing bolt on in the head.
Only things I can find and sell is a big bore kit 283cc or 298cc. $200 delivered
CDI I can get a 3 or 4 level RPM limiter and or racing/no limit rpm CDI etc. unsure $
Carb the best is a carb versy simular to the Lectron at around $400 delivered -touch and go.
$ is USD
Old 12-10-2019, 02:16 PM   #3
franque   franque is offline
If you're in the US, you could send your cams to webcams and get a custom grind, but it might be difficult because I'm sure they've never done an NC250 cam. You might have to send them a spare head and cams to make sure you get a cam built that won't cause the motor to blow up. Best bet (cheapest/easiest) would be to make it bigger displacement and port it.
Old 12-11-2019, 12:42 AM   #4
pete   pete is offline
pete's Avatar
GasGas used the NC250 motor in there 6 day enduro bikes
after the carbed Yamaha WR250 motors run out and Yamaha would not
sell Gasgas the new reverse cylinder injected motors..
look at what cam Gasgas were using...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-12-2019, 06:09 PM   #5
You could change the engine out for the NC450 - slight mods etc to fit but fairly staight forward.
Head is bulkier so MAYBE tank clearance issues
