Old 12-01-2019, 01:33 PM   #1
ChipToothy   ChipToothy is offline
Rear brake broken?
Removed the rear brake caliper to pull the wheel to swap tires and now this morning the foot lever is floppy and the pads aren’t grabbing. I pulled the caliper off and put it back on hoping that would work but nothing changed. It’s got plenty of fluid and worked fine before I changed out the tire. Any guesses? I was hoping that maybe some water got in there and froze from when I gave it a wash and it just needs a thaw????
**I poured water over it all and it behaved normally for a couple of minutes so mystery solved. It’s too dang cold for this!
File Type: jpg 83DC19E8-1D96-47D2-9432-4644C7787CA6.jpg (20.2 KB, 240 views)
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
Old 12-02-2019, 02:31 PM   #2
diyRdie   diyRdie is offline
diyRdie's Avatar
I was just out riding yesterday here and it was about 29°. But I make a habit to never wash my bike.
Good judgment comes from experience, and often experience comes from bad judgment.
MY BIKE'S THREAD
Old 12-05-2019, 04:18 AM   #3
Frag2   Frag2 is offline
Most brake fluids ( Except for DOT 5 types ) are made from some type of glycol based compound. Most of those compounds have a freezing point of around -40 Deg C . That is from online search on brake fluid , Ive been out of bikes for while lot of changes since I owned 1. What remember if have fluid that's been there while it goes bad or is less effective -40 C is cold, if just wasted an had ice on it well. Hope not knowing much helps= Since ive been out of game long time
Old 12-05-2019, 04:43 AM   #4
Mudflap   Mudflap is offline
Probably just pushed the pistons into the calipers a bit. Pumping the brake peddle a bunch of times should return things to normal.
