Old 11-23-2019, 05:36 PM   #1
omorin92   omorin92 is offline
Doh! XF250 Exhaust bolts missing
Hello, during my ride home from work, my exhaust (header?) bolts came off and although I made it home, I will not ride until I find the right bolts. Extremely loud. I bought some bolts to try from ACE hardware, which none were the right size. Is this something I can find online to order specifically for the XF250? Or does anyone know the proper size bolt to buy? THANK YOU
Also I've heard people using other make parts on the XF250?
THANK YOU!!!
Old 11-23-2019, 06:47 PM   #2
OneLeggedRider's Avatar
So they're bolts and not studs and nuts? 🤔 I'm not familiar with your particular bike but more than likely you can use studs and nuts from the brozz or CSC tt 250. Or get you some hardened metric bolts and lock washers from the local hardware store. As long as it screws in 4 turns without any binding you've got the proper thread pitch. Studs and nuts would be better though.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 11-23-2019, 06:52 PM   #3
NzBrakelathes's Avatar
M6 or M8 I’d think
It’s just a bolt or stud etc
Old 11-24-2019, 08:59 AM   #4
dh   dh is offline
Found it
Yeah I'd be careful too, don't want to strip anything. SSR supposedly has every part of these bikes in their inventory, but you can't order online or direct from SSR. Dealers can get it though. But this is easy... Looks like you need Allen bolts: M8x35. Lock washers too.
If you want to look up parts online in English, check the site I searched below.... Copy and paste their part numbers into Amazon and you might be able to order there.
2013 SSR XF-250
exhaust xf250
