Old 11-22-2019, 06:37 PM   #1
Armycopter   Armycopter is offline
Armycopter's Avatar
Steering Stem Bearings
Does anyone have a part number for steering stem bearings on the Brozz? Would like a quality bearing. They are not the tapered style. Thank you.
2019 Bashan Brozz 250
2019 Honda Africa Twin CRF1000L
Old 11-22-2019, 07:11 PM   #2
Armycopter's Avatar
Originally Posted by jeffrey View Post
Dan has the part numbers in his Hawk guide for ALLBALLS RACEING taper bearings that might fit your Brozz. The kit part number is 22-1021
Thanks Jeffrey, i was hoping to not have to pull off and replace the races. They look good, I was hoping to just replace the bearings themselves. When I opened up the triple tree, I was expecting tapered bearings but all these ball bearings fell out and I’m not sure i can find them all. I can’t believe how old school this thing is. I should have been more careful opening it up.
Old 11-26-2019, 07:25 PM   #3
Armycopter's Avatar
Ended up just buying some 3/16” ball bearings off amazon for $5. It’s going back together the way it came. Everything is good.
