Old 11-21-2019, 08:41 PM   #1
mijivey   mijivey is offline
Hwbnde vm26 purchase
Hi Chinariders, I have ordered a Hawk and purchased parts in anticipation of my build. Upon receiving and disassembling my new carb, I found a 100 main jet and #40 six-hole pilot jet. I will have an eBay exhaust and pod air cleaner...so jetting will start at a 110-120, but am confused on the pilot. The rebuild kit(included with carb purchase) has an unmarked 8-hole pilot. I am in Florida/sea level so would appreciate a starting point pilot jet!?!?! 6 hole or eight? Thank you for any input....greatly appreciate this wonderful resource, respectfully, mijivey
Old 11-21-2019, 10:38 PM   #2
Duckman   Duckman is offline
Duckman's Avatar
So for what it worth I have the 2020 TBR7 as well as the 2020 Hawk. I also ordered 2 of the same carbs you did. I live at 650’ in the foothills of the Cascade Mountains in Oregon. I installed the 120 main jet and left the Factory pilot jet installed “ mainly because I ordered the wrong pilot jets”. I have the factory exhaust still and they both run great. Oh I also turned out the air fuel mixture screw out 13/4 turns. Hope it helps. At least they are easy to tinker with.
Duckman out
Old 11-22-2019, 06:20 PM   #3
Thank you for your response Duckman! What size pilot jet were you considering? Do you recall if your's is a 6 or 8 hole type??? Thank you for any info
Old 11-22-2019, 11:58 PM   #4
OneLeggedRider's Avatar
The general consensus is the unmarked jet in the rebuild kit is a 20. Which even on a bike that hasn't been modded isn't big enough. Start off with a 22 and put a 25 in it after you've done the performance exhaust etc. Your bike will start and run better with a big pilot and a small main jet, trust me.
https://www.amazon.com/gp/aw/d/B07QX...b_b_asin_title
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 11-23-2019, 07:43 AM   #5
diyRdie   diyRdie is offline
diyRdie's Avatar
I have a vm26 on a magician (same engine as hawk) with purrformance exuast no cat and pod type air filter. I'm at 740' above sea level. I run a 25 pilot and a 115 main. With the clip in the middle position. Seems to work great.
Good judgment comes from experience, and often experience comes from bad judgment.
MY BIKE'S THREAD
Old 11-23-2019, 08:00 AM   #6
We put a 25 pilot in Jay's Hawk, 1.5 turns on the screw, needle clip center position, 110 main and the elevation is about 760'. Starts and runs great.
Old 11-23-2019, 10:18 AM   #7
Thank you all for the valuable info, very much appreciated! mijivey
Old 11-23-2019, 05:29 PM   #8
NzBrakelathes's Avatar
Remember pilot jet is controlled by the air screw
If bigger it's open less
Smaller open more
You need to tune it at idle to find the lean to rich area
Not just xxx turns out
Old 11-23-2019, 06:32 PM   #9
Smaller open more
Yes Tako, the proper procedure for tuning the FUEL mixture screw on the Mikuni clone is turning the screw out till you achieve your highest idle, then turn it back in till you notice the slightest rpm drop. As long as it's between 1 and 2 turns out you've got the right size pilot jet. If you're skilled enough to get it at exactly 1.5 turns out then you've got the perfect size pilot and can move on to the main jet. Then just adjust the needle for a smooth transition between the two. Easy peezy lemon squeezy.
Old 11-23-2019, 06:50 PM   #10
Same as stock carb
Both are basically the same if not generally just the same
Old 11-23-2019, 10:20 PM   #11
Same as stock carb
Oh my, still the stock carb which is finicky, and difficult to tune even if you can source pilot jets for it. Or the lovely Mikuni clone that you can tune by recommendations alone and have it running wonderfully in 5 minutes. Decisions decisions.. 🤔 😅
Old 11-24-2019, 11:09 AM   #12
Only if you don’t know what your doing huh
Both same design, but you choose
Old 11-24-2019, 04:15 PM   #13
I went with the Mikuni clone on my first Hawk out of pure laziness. I couldn't be bothered to go through the effort of removing the sealed screws and mixture screw cap. Went straight to the mikuni clone, followed some suggestions I found on here, and then tweaked those suggestions by upping the pilot jet and dropping the main jet.
On my new bike I went with the pz30b. Took longer to get running right, but in the end it ran just as good. The lack of pilot jet options was annoying, and the main source of frustration for many.
Having helped a couple other friends with their cg clone bikes, one mikuni and one pz30, it was a similar story. The mikuni clone was up and running in an instant, the pz30 too a bit longer, but at least his used keihin jets. In the end they both ran about the same.
Honestly, I think it is the mikuni jets themselves that make the small difference in how the bikes run/ride. Be it the taper of the jet orifice or the location of the emulsion holes in the pilot jet, they are just a lot less finicky to get up and running. Plus, for 90% of the guys on here you can order the carb and 4 jets, 2 pilot and 2 main, and call it a day
Just my 2 cents.
Old 11-24-2019, 09:11 PM   #14
Exhausting to say the least.
Old 11-26-2019, 12:28 PM   #15
newbie88   newbie88 is offline
Piggybacking on this since I have similar questions!
I recently got the same carburetor as you and put in the 110 main jet. Now I am having issues starting the bike compared to when I had the PZ carb.. but maintains idle fine after it warms up.
Did some searching and looks like I need to up the pilot jet as well?
I just ordered a #25 pilot in hopes that it will work for me.
I too am at sea level in Houston. Temps seem to be in the 50s-60s recently. Thanks!
