Old 11-21-2019, 12:51 PM   #1
JoeRivers   JoeRivers is offline
Head Scratching Grom clone 520 chain conversion
I am currently upgrading my clone to the zs190 and was looking into upgrading the chain to a 520 chain.
However, I could only find the rear sprocket and not the front.
Before I make the CAD and get a custom one laser cut, do any of you know if there is already a 520 front sprocket made?
In that same line of thought, are any of you interested in a 520 conversion? I plan on getting them laser cut from some higher carbon steel and heat treating them.
Old 11-22-2019, 05:45 PM   #2
scoot newb   scoot newb is offline
scoot newb's Avatar
Why would you do that? 428 is even overkill and adds more spinning mass. 420 is fine.
I have a 190 with a grom hub and cush drive and went down to 420 from from 428 sprockets and chain. No problems. Others running the Daytona 212 kit with 4v head are still running the clones stock 428 stuff with a grom hub and it is fine.
Old 11-22-2019, 07:58 PM   #3
Maybe I should go to 428, the 420 chain I put on it stretches too much. Plus i like to go on the size of overkill for reliability
Old 11-23-2019, 12:20 AM   #4
Whisky   Whisky is offline
Whisky's Avatar
#520 would be a very tight fit, I run a #428 mostly because it doesn't stretch as quickly as a 420 and I'm getting to lazy to be swapping chains all the time
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 11-23-2019, 05:54 PM   #5
I think a good o-ring #428 ought to deal with anything even a hot Zs190 swap, we talking at the farthest end possible 212cc, you just dont need a 520 for that. Not enough weight or HP / Torque stress to need a 520, but you can put what ever makes you happy on there, but I think anything over #428 is going to cause as many issues as it solves , especially on the front sprocket case clearance .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 11-24-2019, 11:03 PM   #6
I didnt think of the clearance issue. It did sound pretty nice to have a chain I never have to adjust.
Old 11-25-2019, 11:23 AM   #7
wlfpck   wlfpck is offline
Most people go 428 as the Grom has aftermarket sprockets that allow for 428.
Don't think the Honda Grom has a 520 sprocket available. But there could be other sprockets that may work with a 520 chain if you really want to go that route.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
bd125, sprocket, zs125
