10-25-2019, 09:07 PM | #1 |
Tao Tao Rhino rear brake issues....no light
Whats up fellow riders
I been searching all over for this issue but cannot find....so if you know of a previous similar issue just send me there My front lever brake works fine....rear light comes on....starter works when pulled in.....my question is ....isn't the rear foot brake pedal supposed to do the same? my rear light is not coming on when I press on the foot brake pedal and the Rhino does not start when I press the foot brake pedal Maybe I have a crap connection.....I tried to trace the wire from the rear brake pedal....and I had to already replace the fuse....everything else works tits.....I was told to replace the fuel line because the come with crap hole line....and it is only a matter of time it will start flaking and ruin the carb any insight into how I can fix my rear brake light to go on with the rear brake pedal peace out anyone in the San Jose CA area want to go riding let me know |
10-26-2019, 03:56 AM | #2 |
Is the rear brake switch adjusted right? Yes engine should start and brake light should work with the rear brake.
10-26-2019, 01:25 PM | #3 |
Hey there Muflap
I serious do not know......if it is adjusted right Everytime I get my face down there and press the rear brake pedal with my hand it all looks like it is going fine I would not be able to tell if it was adjusted right .....damn......if you can let me know what an adjusted correctly rear brake pedal should perform like.. ...maybe the fuse back down in that area could be the problem.....it went out once when I had the key on and when I took it out with the key on.....grounded shorted out....replaced it .......so maybe that is the culprit it's really strange the whole entire concept of the particular engineering of that rear brake area fuse and how it all kind of just sits there who knows any one near me in San Jose CA who knows about all this I can trailer it over to your garage or come over to my place not giving up!! hahaha Vince |
10-26-2019, 02:22 PM | #4 |
The switch is simple. A standard motorcycle brake switch used for decades. Pull the pin far enough out and it completes the circuit turning on the light and enabling the starter. Try pulling on the switch pin or spring by hand or unplug it and touch the two wires from the harness together which will bypass the switch.
10-28-2019, 01:39 PM | #5 |
safety features on atv
check your rear brake light sensor for the foot brake...… I tell people to put a big gob of silicone on the threads … because it is plastic... you can not tighten it up.... it comes out iof adjustment ,.. and the foot safety switch does not let you start it.... you will see it in the video... when he shows you the rear disc brake... it is on the righ side... just after the foot brake lever... mounted to the frame.... it is activate when you step on the foot brake... and the spring pulls the plunger out.... check the adjustment.. and it will be fixed..... the odd time they are touchy to activate....
10-28-2019, 01:41 PM | #6 |
atv safety features,,,, foot brake sensor
forgot link
10-31-2019, 04:43 PM | #7 |
Update
so after seeing the plastic part below....I came to the conclusion my sh#$% broke ! now I need to order the replacement part... any idea the part # ???... Had no idea it was busted...see pics......I thought it was supposed to come out and be in 2 pcs......oil well.....the part on the rear brake is broke as the day is long hahahah NO WONDER ...this is my problem right...why it is not letting me work the starter or the light working???....duh! looks like the plastic is busted in two...... who knows the part number see pics |
10-31-2019, 05:03 PM | #8 |
Universal switch. Easy to find. I would change it out to a hydraulic switch.
https://www.amazon.com/s?k=motorcycl...b_sb_ss_i_8_17
11-05-2019, 03:40 PM | #10 |
Plastic nut
That's why I tell my customers to put a big gob of silicone on the threaded part... so the nut can not come loose as since it is plastic... you can not tighten it up... that way it does not come loose and out of adjustment... yes you can get a lot of other parts to use... ebay is the cheapest way... wait from CHina.. or look at local parts sellers on killergokarts.. familygokarts… or partskit… google it.. Chinese parts dealers.
