Looking for a quad now
I’m about to pull the trigger on a Tao Tao Rhino 250 I’m just hoping it’s got the same cult like following as my RPS Hawk. I see they share the same engine family. And I’ve watched every YouTube review I can find. What do you guys think of them are you happy with yours? Or would you have bought something else?
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
Like all Chinese bikes the Rhino has some quirks. The engines are bulletproof but things like ball joint rubbers, wheel bearings, etc., will need some attention. Its a simple machine and easy to work on. Mine has somewhere around 600 enjoyable hours on it so far. It's my main transportation when I'm boondocking in Arizona every winter.
I kinda figured wheel bearings were shipped kinda greased and any China rubber is half dry rot that’s the norm for these. I didn’t want the GY6 engine and belt transmission cause of all the hills and farm chore hauling. I think the clutch setup will last longer then the belt drive.
I know you said you wouldn't want the GY6 engine and belt drive but I would look into the Raptor 200 if you changed your mind.I bought the Bull 200 going on 3 months ago,I haven't pull anything with it yet,still trying to come up with a better tow hitch,but I don't believe it would have any trouble pulling stuff which is what I plan to do when I get a better hitch.I have a ball mounted on it right now.You will have to make some kind of hitch for the Rhino,it doesn't come with any mount at all.
I have been beating the hell out of my rhino. if I see water or mud I am in it just like a little kid again. the only issues I have had are I lost a bolt from the chain tensioner replacement cost $1.59. that's it after the carb swap and front sprocket swap it has been great.
I have been plowing, towing, mudding, hunting, ice fishing and trail riding with it so far. including a 100-mile poker run where I kept the throttle pinned for hours at 8000+ rpm and still runs great. I am not kidding throttle was pinned wide open for 1-1.5 hours at a time with only a 5 min cooldown in-between stops. I did that for 11 hours that day. |
Same here I beat the hell out of my Rhino...I tow some heavy loads up steep river banks (smaller front and larger rear sprocket)..... in, through, and out the creeks. I think you'll find it a very capable farm machine.
Well a Rino is on the way from Q9 powersports. They already called to confirm the order. Might be here by the weekend!! I post some pics when it lands. It’s the first new one for me, I’ve always had mid 80’s basket cases something clean will be nice for a change.
You have officially become a true Chinarider.
#9 | |
2013 SSR XF-250 |
