Old 10-14-2019, 02:19 PM   #1
kvgeorge1   kvgeorge1 is offline
Carb leak Hawk250
I am having a fuel leak at the brass pin closet to the top of the carb in the attached picture...
Can anyone tell me what that pin is called and what would cause a fuel leak there?
When I turn on the fuel from the petcock - it streams out like a waterfall.
Old 10-14-2019, 07:57 PM   #2
NzBrakelathes's Avatar
That pin is just a guide for the inner round throttle plunger - shouldn't be able to get fuel coming from there at all.
Old 10-14-2019, 08:44 PM   #3
its the overflow. you can see the cast tube running up to it. your float is stuck open for some reason.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-14-2019, 09:24 PM   #4
But his pic he’s pointing to guide pin, over flow is from bottom of carb and the hose attached.
I can’t work out why he claims it’s coming from the guide pin cause no way you could get fuel there up that high
Old 10-14-2019, 09:30 PM   #5
The hose on the bottom is for the bowl drain, not overflow.
