10-14-2019, 12:03 PM | #1 |
K&N filter part no
Is HA-0502 for the TBR7 and bikes with the flat "lawn mower" style filter airbox
10-14-2019, 12:20 PM | #2 |
For the price I would just get a cheap pod filter. I ride primarily in the dirt/desert.
For my GSXR I have the K&N filter. Pod filter easier to take off and clean too. (my next project) XD Edit: That looks exactly like my Bashan BSR filter, size 135mm x 115mm
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 Last edited by AresROC; 10-21-2019 at 01:54 PM. |
10-14-2019, 12:47 PM | #3 |
I considered that at 1st, but my leg would have been touching the pod for a good sized one and this looked a cleaner installation.
10-14-2019, 01:03 PM | #4 |
I had one of those. It was horrible excuse of a filter. They are used dry no oil ever, the face is dyed red just to confuse you. They don’t fit well too short so you’ll need a bent wire square shaped spacer to fill the gap. Way to restrictive on flow you’ll see. All the Amazon reviews aren’t great I thought my experience would be better.
I’d like to cnc a frame from plastic and glue in a UNI foam filter. I have the materials on had just no open time on the Machine. Winter project.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
10-17-2019, 10:27 AM | #5 |
IMHO, K&N is overpriced junk. Just get a washable foam filter.
10-18-2019, 08:09 PM | #6 | |
10-18-2019, 09:47 PM | #7 |
My mods as follows 120 main 27.5 pilot PZ30 paper filter stock exhaust w/ no cat. Muffler tip is gutted out. Ported head decked .040 for compression. Air box lid is opened up. It’s actually a little lean when it’s real hot out.
10-21-2019, 08:36 AM | #8 |
This is exactly what I plan on doing to my bike, I've been putting it off due to work. I like the stock look with added water protection. I think the K&N for mine will be like $26 and I may have to do light modding to get a good seal.
Looks great!
10-21-2019, 11:39 AM | #9 |
If its lean with it really hot out, it should be even leaner when it gets cooler outside.
10-21-2019, 01:38 PM | #10 |
Dan I think you should start a thread and call it "Basics of carburetor principles, tuning, and theory 101" and possibly Jerry can make it a sticky, as the knowledge is clearly needed here.
11-23-2019, 02:31 PM | #11 | |
K & N or ???
K & N's in the $45.00 plus range. I must be looking wrong. HELP! |
11-23-2019, 02:41 PM | #12 |
I have a slightly used K&N from my Hawk I’d be willing to lose, need the room. It’s current use and better then OEM use is to hold down my 3 tier pallet rack.
