Old 09-26-2019, 08:50 AM   #1
Audihuff   Audihuff is offline
Audihuff's Avatar
hawk replacement battery
straight to the point. Id like a new battery for the hawk. i see a lot of outdated/unavailable batteries from old threads or batteries that need extra foam or spacers. Are these our only options? Id like a Plug and play amg maybe. what are yall thoughts?
To light a candle, is to cast a shadow..
Old 09-26-2019, 01:31 PM   #2
wedooit   wedooit is offline
wedooit's Avatar
I purchased this for our BMS250, not too sure if it will fit the hawk. got it from batteries plus...YB7BB25
The posts are opposite of the original, but works great.
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome".
Old 09-26-2019, 05:04 PM   #3
The factory Hawk battery is not a common size. That is why you see foam spacers being used with smaller powersports batteries. I have a ytz7s style battery in mine. Double the cranking amps of the original battery and it works just fine, but yes it required foam blocks to take up the space.
Old 09-26-2019, 06:27 PM   #4
alex_in_az   alex_in_az is offline
how long are you guys getting out of your batteries? I recall life expectancy on my old Panterra was about 9 months before they died. I figured it was a combination of heat and vibration that did it.
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 09-26-2019, 09:33 PM   #5
Wild Dog   Wild Dog is offline
A Drop in replacement for the chinese battery is the Yuasa 12N9-3B
https://www.amazon.com/Bater%C3%ADa-...sr=1-2-catcorr
Yes it's an old school battery, is not gel and doesn't have any other magical property. Just an old school acid battery, i been using it for almost two years and it works just fine.
I even activated it with the acid.
Old 09-26-2019, 09:34 PM   #6
Typical life span of a small poweraports battery should be 2 to 3 years, but that can depend on a variety of factors.
