09-21-2019, 07:07 PM | #1 |
what does this pipe do?
coming off the exhaust and running up to the area under the tank? some kind of emissions gear?
09-21-2019, 07:39 PM | #2 |
Remove and blank off
It’s air injection n useless I’ll include a blanking plate with your soeedi |
09-21-2019, 07:48 PM | #3 |
Ok then an angle grinder cut it off n weld a washer in place to blank it off
09-21-2019, 10:11 PM | #4 |
Is that an upgraded ignition spark coil? I want THAT!
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
09-21-2019, 10:23 PM | #5 |
I've got an aftermarket pipe to replace the whole lot
09-21-2019, 10:23 PM | #6 |
That's what it came with
09-21-2019, 11:25 PM | #7 |
On the TBR7 it's an air "injection" system that lets fresh air into the pipe to help burn off hydrocarbons as they enter the catalytic converter. All it consists of is a one way valve that works off of exhaust pulses. The other end literally goes nowhere, not to the airbox or intake manifold, just a filter up under the tank. Feel free to cut it off and patch/weld the hole. Or do the smart thing and get an aftermarket exhaust.
