09-14-2019, 01:09 PM | #1 |
Carb issue driving me nuts.
I put an aftermarket exhaust and a pod filter in place of my airbox on my storm. Now I'm having a hell of time jetting it. I've tried with my stock Pz30 and the pz30b I got from Tako with the same results. Idles beautiful, past quarter throttle it falls on its face, full is OK for a second. I have tried a 34-42 pilot with neat the same results. Also have tried 110-20 main with no luck and a the af screw between half and 3 turns out. Only other thing than changed is I adjusted the valves when I had it apart. Ran perfectly before this adventure lol. I attached a video of me rolling on the throttle in nuteral. Once you get to near 3/4 throttle it clears up, at least in nuteral. While in gear if you crack it full throttle it takes of for a second and starts sputtering, adding choke doesn't help either so I don't think it's lean .any suggestions?
