Old 08-17-2019, 01:50 PM   #1
Temok747   Temok747 is offline
New Hawk 250, Clutch out problems.
Hi Everyone,
I got my Hawk 250 yesterday and assembled it all together. It starts and runs great. I gear into first then slowly let out the clutch but the engine will completely stall without even moving the bike.
Does anyone know what could be causing these problems?
Old 08-17-2019, 07:11 PM   #2
Digger   Digger is offline
Have you tuned the carb yet?
Old 08-17-2019, 09:12 PM   #3
Doh! Already Tuned.
I adjusted the carb for idling, runs great. The bike runs and idles in neutral and when the clutch lever is in too. I've also adjusted the clutch cable appropriately It seems to happen the second I drop the clutch fully in gear. It stops followed by a click noise. I think it might be electrical but I'm unsure.
Old 08-17-2019, 10:11 PM   #4
pete   pete is offline
pete's Avatar
might just be your terminology...
DROP the clutch!!! ... you feed it in slowly with a few revs on..
you could look at the clutch and side stand switches see if they are working correctly..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-18-2019, 12:21 PM   #5
Question
I obviously slowly let out the clutch, but its like the bike shorts out somewhere as soon as its fully released.
I Bridged the clutch switch to see if that was the problem but it didn't help either. There's no side stand switch either.
Anyone else have any ideas?
Old 08-18-2019, 12:27 PM   #6
Tashka   Tashka is offline
If you rev it and release the clutch, will it begin to drive?
Old 08-18-2019, 12:43 PM   #7
There doesn't seem to be any power going to the rear wheel. It just simply shuts off like it was stopped with the kill switch.
Old 08-18-2019, 02:53 PM   #8
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Ok work through the process of elimination. Pop off the master link clip pull the chain through and see if it will repeat the stall or will the front sprocket free wheel when you dump the clutch.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 08-18-2019, 09:59 PM   #9
Update
Found that the rear wheel was completely locked up. I will take off the chain tomorrow and inspect it for free movement thanks!
Old 08-18-2019, 10:48 PM   #10
OneLeggedRider's Avatar
Sorry but I gotta
Old 08-18-2019, 11:19 PM   #11
probably rear brake maladjusted
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 08-18-2019, 11:38 PM   #12
Adjusted the rear brake but still no movement. Well see if the motor spins tomorrow.
Old 08-19-2019, 12:19 AM   #13
Oh, I thought you had confirmed it was the back tire being locked up. If the tire spins freely with the chain off and the front sprocket won't, that's a big problem.
Keep us updated on what you discover.
Old 08-19-2019, 01:40 AM   #14
pete's Avatar
You must have pushed it around or moved it.... So how did you do that
with the rear wheel locked up...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 08-19-2019, 10:56 AM   #15
Is the bike in gear hence why the tire doesnt move ?
Are you confirmed in Neutral.
In this day and age, no reason to not shoot a quick vid with your phone and post it.
