Old 08-09-2019, 01:31 PM   #1
Adrenalcookie   Adrenalcookie is offline
i require your wisdom on a vader gen 2
What size bolts are the engine mounts? im shopping for class 12.9 ones but i see many different sizes and have no idea on which one to pick, Also are there any exhausts that do not require modification to fit?
Old 08-09-2019, 05:25 PM   #2
Whisky   Whisky is offline
Whisky's Avatar
120 and 130mm x 8mm bolts. Exhaust from a Honda dax, z50, z70 I'm sure there's some others, someone else will chime in.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 08-10-2019, 09:48 AM   #3
If you can let me know if you want a low pipe or a high pipe i can link some that we know for sure will fit the Gen2 Vader. Just to give you an idea, i own a fairly modified Gen2 Vader and this is the exhaust i run : https://www.ebay.com/itm/Racing-Exha...AAAOxyQj9RSTzL
A more basic low pipe is this one :ttps://www.ebay.com/itm/Stainless-Steel-Exhaust-Pipe-Muffler-For-Honda-Monkey-Z50-Z50A-Bikes-Skyteam-2/253333849871?hash=item3afbdfc70f:g:FIwAAOSwttVaRju V
There are a few more options out there, but these two are generally the most popular.,and both are confirmed to fit on Gen2 Vaders by Owners here .
Hats off to Whisky for getting you the engine mount bolt sizes, i had them written down " somewhere" but was unable to locate it like i was my exhaust system info.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 08-10-2019, 01:10 PM   #4
SilverBullet51   SilverBullet51 is offline
I'm running a kepspeed gp1 for a dax, I bought it off motorkit's website. It's a bit pricey compared to others but the quality and fitment are spot on. Shipping from overseas was surprisingly fast. Only took 5 days for me. I like the one redcrow linked but I wanted carbon fiber.
Old 08-10-2019, 05:28 PM   #5
Whisky's Avatar
I'm running the same as silverbullet51, all exhaust from kepspeed are very nice but sure there are cheaper decent exhaust. Thanks Redcrow, I only knew right off the bat because I just got done swapping in my 190.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 08-15-2019, 11:12 AM   #6
are there any high pipes?
