Old 07-30-2019, 02:27 PM   #1
Chris45   Chris45 is offline
Razz 110cc
Hi guys, I need some help please. I bought new neutral and Reverse gear indicator lights. But cannot see or figure out where to wire them into? My gear selector switch that goes into the gear box only has 2 wires....... any help is appropriated.
Old 07-30-2019, 02:42 PM   #2
Mudflap   Mudflap is offline
The way this works is battery + is connected to the bulbs. The negative wires from the bulbs go to the switch on the transmission. When in neutral the switch grounds the wire from the neutral indicator bulb, completing the circuit. Same with reverse.
Old 07-30-2019, 06:44 PM   #3
Awesome! Thank you for the help! So easy why can't any of this be found anywhere. Thanks again!!!
Old 07-30-2019, 07:01 PM   #4
Wink info
just got to look at the right place..... like here
ABIBABA ATV ETC
Old 08-30-2019, 04:02 PM   #5
Teresa   Teresa is offline
My taotao 110cc atv will not run more than 1 second after it starts. What's up with it
Old 08-30-2019, 07:59 PM   #6
Bruces   Bruces is offline
It’s broken .
Old 08-30-2019, 11:02 PM   #7
Deckard_Cain   Deckard_Cain is offline
It is customary to start your own thread topic about a separate and distinct issue....
But, you need to give us A LOT more information than that.
It could be a carburetor problem, something on the CDI ignition, a large leak in the intake after the carb, valves out of alignment, engine compression too low...
With what you've given us, all we can say it was Bruce already did. It's broken.
