Bull 200 Battery
Has anyone replaced their Bull 200 battery? Looking for suggestions.
Looks like the same one used in the Rhino and others. Common size. I get mine at Walmart. They hold up just fine.
Yeah, that's where I was gonna pick one up I think. Just curious if others got them elsewhere.
Yuasa makes the best batteries IMO but they're expensive. Any motorcycle shop can order one.
![]() ![]() Chinese had made OKish AGM in this size ![]() ![]() Motobatt (that yellow thingy) of course had this size available BUT the price ![]()
I put my Bull 200 together in the barn,my garage is so full you can't do anything in there.While I was putting together I was charging the battery also,heard a loud pop then a bing,bing,I said what the heck was that,looked all around then seen the red rubber vent cap on the ground,it had hit the ground with so much force it bounced up and hit the barns tin roof.
I got 4 or 5 car chargers and I didn't want to go dig one out of the garage so I grab my high frequency 4 amp I already had in the barn and forgot about the vent cap.4 amps is a little too much charger for that small of a battery,but charged it in less than 20 minutes.
#10 |
Probably going to go with a AGM battery come winter,maybe up the amps to 10 or 12 or higher as long as it will fit so I can have a little extra power for the winch and lights I plan on installing.
#11 |
Here's the battery I might try come winter,
https://www.amazon.com/Weize-YTX14AH...HVBHTVQ62YJY81 I think it will fit plus help with extra lights and a winch,it will be a tight fit.I don't think the battery that come with the Bull will lasts once it turns cold.Or this one https://www.amazon.com/YTX14AH-BS-Ma...s%2C216&sr=1-9 |
#12 | |
#13 |
I just wonder if using a higher ampere-hour battery will hurt the charging system,can't be to robust of a charging system.
#14 |
#15 | |
