Old 07-23-2019, 03:55 PM   #1
KirbyJ   KirbyJ is offline
Please HELP 250cc Tao Tao Rhino noise
Hello
Ive only had this atv for a week and getting a noise on the left side (as you're sitting facing forwards) It right where you change gears. Theirs a cap to unscrew on the top for some type of oil. Beside the starter I cant find any nfo on oil amount or the oil type to see if it has enough. I will try to upload a pic.
Old 07-23-2019, 04:04 PM   #2
screw cap
this cap is for timing marks... NO OIL.... your STATOR IS IN THERE...
ABIBABA ATV ETC
Old 07-23-2019, 04:05 PM   #3
That cap is for access to your timing marks on the flywheel. No need to add oil in that cap location. The dip stick on the opposite side is where you check and add oil. Not sure if your bike has a sight glass. if it does it should be half way the glass. Only use oil rated for wet clutch.
2004 Honda ST 1300
Old 07-23-2019, 04:06 PM   #4
LOL we must of been typing at the same time.
2004 Honda ST 1300
Old 07-23-2019, 04:22 PM   #5
What kind of noise is it making? Grinding? chatter?
2004 Honda ST 1300
Old 07-23-2019, 08:30 PM   #6
If it has the original oil, get it out and put new in. Most use Rotella T 15w40. As Jerry said, Check the oil level on the right hand side.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 07-24-2019, 01:38 PM   #7
Yep. Change the oil. It holds a quart.
Old 07-24-2019, 01:44 PM   #8
Oil level is dead on, just a rattling noise where the cap is you said for timing marks. Will change oil and see thanks guuys
Old 08-07-2019, 06:32 AM   #9
dugndeep   dugndeep is offline
Could be your stator plate is coming loose.Take that outer chrome cover off,see if anything is loose inside.With the cover still off,start the atv up and see if you can see if it is rattling.
Old 08-07-2019, 09:53 AM   #10
GrandKidsMX   GrandKidsMX is offline
Are you sure your chain is not too loose and rattling? If you don't know how to check the oil I'm guessing you haven't adjusted your chain tension either???
