Nibbi Carb
So is there any specific jets for nibbi pe30 like the vm26 mikuni clone? Or if Iget pe30 jets they will fit not like the vm26 where the pilot requires a vm28/486 ect.
"If there's no modifications it's not fast enough!!!! Hawk250RedRyder2018 FlyRacing/D.I.D./ProTaper/JTSprockets/Nibbi30/DPR9EIX/PNP/KendaWashougal2/Acerbis/AlpinestarsTech5/HJC/.........TheRideContinues........RockyMountainHigh ..........LIFE ELEVATED!!!! |
99101-393 mains and N424-21 Pilot jets just like the PE30. The harder jets to find are the 30-32 sizes, mostly found as non OEM jets. Most OEM supplied jets start at 35.
Dan, what do you think about this listing? How do you think it will compare to the Nibbi PWK30?
https://www.ebay.com/itm/30mm-PWK30-...frcectupt=true |
Thanks dan your so much help cant thank you enough. Now I'm in process of waiting for the new head and trying get intake for the nibbi I couldn't get the link to work on English TaoBao for some reason and tried to navigate the Chinese one lol didnt work. But ive narrowed these two adapters that should at least fit the head and I can make work hopefully. Another question Dan does the throttle cable work with the nibbi carb I assume it does.
#5 | |
#6 | |
#7 | |
The stock cable should work just fine as far as the throttle and throttle slide ends. Considering the cable is almost a little too long for the PZ30 carb.
That's what I wanted confirm. I wanted to know if the ebay carb was inferior to the Nibbi carb. I'll just pony up, and spend the money on the Nibbi if I do the swap. After dealing with several china bikes, I have come to realize how important the carb is....
Dan, could you suggest a few pilot and main jet sizes for the PWK30 Carburetor? Currently I have the Mikuni VM26 with a 27.5 pilot, and a 120 main. Bike runs good, but a little on the rich side. I am at sea level.
Douglass |
#10 | |
I am currently at a 35 pilot and a 122 main with the needle in the third notch, but I also have my head ported and a longer than standard intake.
#11 |
Thank you Dan, much appreciated! Besides the easier access to the air/idle screws do you think the PE30 will perform better/worse than the PWK30? It looks like from a bolt in the PE30 will fit better with the air filter box, and manifold adapter than the PWK30 carb.
#12 |
On my PWK30 i'm running a 38 pilot and a 125 main. You will probably get about the same performance out of either one.
#13 | |
