Old 06-17-2019, 09:34 PM   #1
Atvdizzle   Atvdizzle is offline
issue with clutch burning out Typhoon 125cc
Hi All, I'm hoping to get some help with a Chinese ATV that I bought second hand. After a little bit of work the engine fires up great and purrs like a cat. When I put it in gear and gave it gas the ATV wouldn't move. I bought a new clutch and installed. the ATV ran fine after the clutch install but it it smell a little like i was burning oil. My 8 year old was riding it around the house at low speeds off and on for about an hour when the same issue with the atv not moving came up again. I drained the oil and it was very dark. I filled with fresh oil but that didn't;t solve the issue. I can't believe he could burn a clutch in such a short amount of time. Any ideas what it could be? If i did burn out the clutch - any ideas what would cause that so I don't make the same mistake? I'm generally handy with fixing things but this is my first ATV project so any advice would be greatly appreciated. thanks Mike
atv, burn, burnt clutch, clutch
