06-16-2019, 04:31 AM | #1 |
Gearbox ratios for CG200 anyone knows?
Hi
I need 1-5 speed gearbox tooth count for input/output shafts for CG200 bikes, if anyone knows? Thanks! |
06-17-2019, 10:46 AM | #2 |
Not all CG200s have the same ratios. Some where I have ratios for the Lifan 163FML and a Zongshen 167FML.
06-18-2019, 08:39 AM | #3 |
I have a spare transmission and i counted the tooth on Input and Output shafts.
I. O. 1. 13:37 2. 17:32 3. 20:28 4. 23:26 5. 25:24 But, the transmission in my Keeway - Zongshen is different, I don't know all gears tooth count, I only know for second gear, and it is I15 O28. So, it has close similar ratio in 2nd, but less tooths, tooths are bigger. I need new gears for third speed, because they are damaged and worn. I wonder if to use this spare gearbox shafts and gears or I need to buy another transmission. So i need some confirmation about the gear ratios of other bikes. |
06-18-2019, 10:36 PM | #4 |
Typical 3rd had 2 settings: https://item.taobao.com/item.htm?id=550156420505
--- For trike Zongshen CG200:
06-24-2019, 07:28 PM | #5 | |
But, the third gear had severe damage, on both gears. The reason may be that the 3rd gears are thinner than the others. I will attach a pic of the gears later. I ended up putting first 4 gears from my spare gearbox, and kept the 5th gear from Zongshen original. The reason is I could not combine org and spare gears. I ended up with little faster 1st and 4th gear, littttle slower 2nd and 3rd, and the same 5th. Here are the ratios: 1st org> 32/11= 2.90 1st spare> 36/13= 2.77 * 2nd org> 28/15= 1.87 2nd spare> 32/17= 1.88 * 3rd org> 25/18= 1.39 3rd spare> 28/20= 1.4* 4th org> 23/20= 1.15 4th spare> 26/23= 1.13 * 5th org> 21/22= 0.954 * 5th spare> 24/25= 0.96 * denotes ratio currently in my bike. Great is I now have normal 3rd gear, with full power and no whining noise. And just to note, my primary reduction is 3.333 (70/21). |
