Old 06-14-2019, 02:55 PM   #1
Inverness   Inverness is offline
Doh! Hawk Down - Now front wheel pointed to the right
Ok so maybe it was a bit wet to ride trails today. lost my mirror and now the front wheel is angled to the right with respect to the front fender, and the handlebars have to be turned to the left to go straight.
Help a noob out, how do I fix this?
Also, is there a replacement mirror I can order on amazon? Have my skills test on Monday for my MC license and don’t want to miss it.
Thanks!!!!
Old 06-14-2019, 03:51 PM   #2
If you mean that the forks are twisted it's just a matter of loosening up the bolts on the triple tree, align and tighten them back up. Just make sure you have the bike supported on a stand and front wheel is on the ground before loosening.
Old 06-14-2019, 03:57 PM   #3
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Most states only require a left side mirror.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 06-14-2019, 04:16 PM   #4
Ok great, this is what I did and seemed to work. Thanks!!!!
Old 06-14-2019, 04:27 PM   #5
Genius! I love this place.
Old 06-14-2019, 04:44 PM   #6
NzBrakelathes's Avatar
I’ve got 1 set of folding mirrors I’ll be in Boston Sunday night can send then or Monday
$15 a pair
Old 06-14-2019, 11:26 PM   #7
Tashka   Tashka is offline
If I got more to ride, I just grab the front wheel between my legs and grab the handlebars and just jerk it until they're straight.
usually I'll loosen and retighten but it's usually good as new
Old 06-15-2019, 07:05 AM   #8
OneLeggedRider's Avatar
What Tashka said. When I laid mine down it was tweaked to the right and I just put the wheel between my legs and grabbed the bars. Easy peezy.
Old 06-15-2019, 09:29 AM   #9
Ariel Red Hunter's Avatar
Thanks!!!!
Ideally you pump the forks up and down with the axle nut and clamps loose in order to get everything in alignment. Then retighten every thing back up. But out in the boonies, just put the front wheel between your legs and twist the handle bars back to straight...ARH
Old 06-16-2019, 12:42 AM   #10
Torgo   Torgo is offline
Torgo's Avatar
From first hand experience myself, the triple-T on the Hawk is made of a relatively soft casting and can be twisted out of alignment from impact if the bike is laid down.
If realigning forks (and axle) with the pinch bolts doesn't buy you enough alignment - that should be tried first - you may have to realign the triple-T itself. I took the front tire off and put a crow bar between the forks and gently applied some counter force to get them back into alignment, effectively twisting the triple-T back to parallel.
You'll know this case applies if the forks themselves seem to no longer be completely parallel, or you see that they don't really align easily thru both mounting points on the triple-T and top plate. A good impact to one side the handle bars can cause this.
If it's bad enough, or if you observe that the metal is actually cracked somewhere, you'd have to replace the triple-T, the top plate, or both.
2015 Hawk 250
