Old 06-13-2019, 03:49 PM   #1
fast92rs   fast92rs is offline
fast92rs's Avatar
Send a message via AIM to fast92rs Send a message via MSN to fast92rs Send a message via Yahoo to fast92rs
bd125-8 Clutch
Just got my Venom bike and I noticed the clutch does not grab until its almost released. There is basically zero friction zone. Are there any adjustments for this? Does it change as it breaks in? I think I saw another post mentioned this but can't find it.
2019 Venom Motorsports X21RS
2012 Harley Davidson Sporster 72
Old 06-13-2019, 06:18 PM   #2
There is an adjuster on the lever under the rubber cover ,and yes it does get better as the bike breaks in .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 06-13-2019, 07:03 PM   #3
fast92rs's Avatar
Yeah I saw that adjuster and the one by the engine. Just wondering if there was some other adjustment I was missing.
Old 06-13-2019, 10:34 PM   #4
Whisky   Whisky is offline
Whisky's Avatar
U can also adjust clutch down by where
The cable connects to the clutch arm, make
Your main adjustments here then fine tune
at handle bars.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 06-14-2019, 01:26 AM   #5
pete   pete is offline
pete's Avatar
On the right side of the motor there is a round cover
held on by two screws..
under that you will find the clutch thow cam and adjuster screw..
if that's not set right you can fiddle around with the cables all day
and get nowhere...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-17-2019, 06:36 PM   #6
fast92rs's Avatar
I adjusted the cable till both adjustments were all the way in. It's slightly better now. Almost seems like the cable may be a tad bit too short. Going to check under the cover tomorrow.
Old 06-18-2019, 01:55 PM   #7
SleepyC   SleepyC is offline
Check that the end of the cable going into the clutch arm on the motor is seated properly. I was having the same issue as you with my Hellcat, and after eyeballing the cable for a few hours and trying to adjust it, I noticed the metal bobbin that fits into the arm was not pushed all the way in. Once I did that I was able to adjust it to perfection.
