Various Hawk 2018 Parts
Hello,
Will send pictures on request. Shoot me an offer. Here's a list: Rear Fender/brake light (entire assembly). Right plastic mounts broke off. I'm sure you could mend this no problem- I just went with a fender eliminator. Everything worked when I took it off. Rear turn signals (Left and right) Stock Carb (basically a take off, used for maybe 5 minutes just to crank the engine and check functionality) Stock Rear Shock Stock Sprocket (4) Honda Kush washers 90128-KE2-940 (common upgrade item used when upgrading rear stock) Stock Stickers (1) Honda Fork seal and retainer (requires some cutting to fit) retainer is part 51447-KA4-004 and Seal is (Will find part number). Replacement for Hawk 250 fork seals. |
Stickers?
Buz, do you still have the stickers for the Hawk? I would be interested. Let me know the cost. Thanks.
Greg |
is the rear brake light assembly still available?
This is an old thread so you may not get a response. The tail light assembly for the TT250 should fit. https://cscmotorcycles.com/oem-parts...dy/tail-light/
