TBR7 rear shock
So i'm trying to get a bit of feedback on the suggested KEOGHS rear shock.
i went through a few posts and wanted an honest feedback. I saw the picture of Dan"s bike and thought a bit tall for me 325mm?( he's tall @6ft 4 Saw a picture of 'one legged rider's ' bike and thought too low for me 290mm? I'm thinking of goldilocks here and go in the middle ![]() I did a quick shock measurement on the TBR and it seems to be 300mm i seem to recall the stock hawk is 320mm. So i would like my bike a little taller at the back than stock so thinking 310mm. Do you guys still have a good feeling about the shocks and spring rates ? or do you feel you would do it a different way if you had to do it again? You thoughts and experience are much appreciated. Also can you put a link to anything that might work better? |
I like mine quite a bit. The rebound adjustment does work, although it only has about 3 or 4 useable positions to work with. Compression damping is quite good, not too hard or soft for my big butt. The linear spring rate makes for predictable handling, and the preload adjustment is a nice feature that the Hawks never got.
Performance wise, it is much better. I can fly over bumps now that would bottom out my factory Hawk shock 10mm length difference equates to a roughly 1 inch change in height, or a bit more than. Overall I am quite happy with mine for what it is. Short of spending $300 for a custom YSS rear shock, which would be better, this was the best route for me. I would do it again if I bought another bike. Did you measure the shock with the rear at full droop (rear wheel off the ground), or with it removed from the bike?
#3 | |
Also Dan an inch height increase would be about perfect for me as i have a 32/33 inseam.
Somehow, i tried to update the post, i updated your post about the inseam? I'm pretty sure your inseam is at least 36.
#6 | |
My inseam is somewhere between 34 and 35. I can flat foot a Hawk with the suspension fully extended.
I'm 6'2" and have a 34" inseam, and can flatfoot the bike with my knees slightly bent. The reason I went with the 290mm which dropped it 3" is because I'm almost 50yrs old and not as limber as I used to be. Even with it dropped I still have a little trouble getting my leg over it.
As far as the quality of the shock I'm definitely impressed. I think I'm 4 clicks from firm on the damping, 3 clicks might be better. And I still haven't added any preload to it, but since I've been making myself sit further forward on the seat for comfort, bottoming out hasn't been an issue unless I really go airborne. I would definitely purchase this shock again. |
Also because of the angles my chain is alot easier to adjust than Dan's.
#9 | |
![]() ![]() i hope this does not end up as a double post as it seems the first time i wrote it it has gone to cyberspace ![]() |
#10 |
I have zero issues adjusting my chain. It's not any different than a standard Hawk on a stand. I just favor it being a tiny bit more slack now. Works out almost perfectly.
#11 |
I'm quite sure you don't. Just with my lower rear end and less travel my rear sprocket isn't far from it's furthest point from the front sprocket at full droop or with my weight on it. Polaris has figured this out. My Scrambler's front sprocket is actually on the swingarm pivot so the chain maintains the same slack throughout the suspension travel.
