06-03-2019, 10:22 PM | #1 |
Handle bar vibrations
So the Hawk has vibes and I except it. I see Aluminum fat bars, Inserts, bar weighs, on and on. Looking for something that works. I don't have a death grip and swapped out the new grips that are awesome! Should I try lead shot and fill the bars? Trying to dump the last bit of bar vibe. It's not uncommon to burn 100 miles on a ride.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
06-04-2019, 10:44 AM | #2 |
In addition to aluminum bars, I wear mechanic's gloves that are designed for impact gun use, with a padded palm. Cheaper versions can be found at HF; more spendy versions are at HD.
06-04-2019, 06:57 PM | #3 |
Aluminum fat bars help, but the addition of bar end weights or brush guards can also help. A bar snake or shot like you mentioned can also help a bit. No matter what you do, there will always be some level of vibration. One type of vibration that is hard to eliminate are the ones that come from more aggressive knobby tires.
06-05-2019, 12:31 AM | #4 | |
06-05-2019, 12:39 AM | #5 |
My Shinko 700s are less aggressive than typical knobby tires and suit the kind of terrain and riding that I do better. Why is simple enough... Better road manners, less vibrations, etc. Not much in the way of forests, beaches, or mountains here in the Central Plains. Lots of dirt roads, fields, and scrub with dry hard pack or gravel/sand mix. An occasional wet land near a river is about as close to a beach that I can get, and that is often more wet clay mixed with sand, or find silt mud. That is about the only instance where a more aggressive tire would be better suited, and those are fewer and farther between. I am on pavement about as often as I am on those surfaces, so having something a bit better on the road makes more sense.
06-05-2019, 01:06 AM | #6 |
Sounds like you need a street oriented Magician for daily commuting, and a full blown Hawk for serious off roading lol.
06-05-2019, 01:48 AM | #7 |
Magicians dont fit giants like me very well
06-12-2019, 09:07 PM | #8 |
Took the plunge.
I ended up with these ProCaken Protapper knockoffs aluminum bars and what a difference they make. The vibes are significantly reduced and my rear view mirror images are stable now. Kind of a pain to reset everything but well worth it at $35 with the adapters. Buzzing along at 55 mph I can feel the stock knobbies now. They're next on the list. Highly recommend it.
06-12-2019, 10:30 PM | #9 |
basically the same bars I have, except mine have Renthal stenciled on them lol. They are great bars, I love mine.
06-12-2019, 11:00 PM | #10 | |
Yes you can use them on the street, but the handling is not really good. Paved road+ Rain+ Knoobies for me that's a big no. I use Pirelli MT60, they have a very good handling on wet roads, great handling on gravel and dirt road, Ok in sand and you can work your way into some light mud. These motorcycles are actually 70 on and 30 off, so i like to use a tire that fits better. Knobbies, just like mud tires on truck. Not hand roads poorly but when used on road, they won't last as long as they should. |
06-13-2019, 12:06 AM | #11 | |
And when it comes to bikes I have logged far more miles on pavement riding dirt bikes than street bikes. As soon as my farm chores were done I was gone until curfew, and got really good at riding without a headlight, oncoming cars won't blind you if you if ya don't look directly at them. So yes, I feel very comfortable riding on knobbies, it's almost all I've ever known. And I try not to ride in the rain, but if I have to I just use a little more care as far as brake and throttle. I just bought my cousin a TBR7 and I'm sure we'll have some difficulty trail riding together because of his sub standard traction. |
06-13-2019, 08:23 AM | #12 | |
06-13-2019, 09:40 AM | #13 | |
06-13-2019, 10:03 AM | #14 |
Fill the stock bars with spray foam. They also sell Bar Snake. Works good too.
06-13-2019, 10:42 AM | #15 |
Just installing the hand guards will kill most of the vibrations. It did on my bike anyway.
