Old 05-05-2019, 12:51 PM   #1
FlatlandsTbr7   FlatlandsTbr7 is offline
Tbr7 digital cluster instal help!
I've had a Tbr7 for a few months now. I love this bike, but I'm going in circles trying to figure how to wire in the cluster from a hawk. Has anyone here done it yet??
Old 05-05-2019, 06:08 PM   #2
These are the pictures of the wire hookups that are coming from the new dash.
Old 05-05-2019, 06:13 PM   #3
The_DJ_Remixer   The_DJ_Remixer is offline
Did you get instructions with the digital dash? That 1st picture, the green on one side and white on the other plug is the one you want. The white side has open plugs. You match them with the colors. I do think the one that says brown w white (not 100%) is actually gold/yellowish...
Then the blue w white stripe goes on the plug above the one youre working on, near the carb. It doesnt actually have a plug to plugin to, youll have to stick it on top or bottom of the existing one, then tape the entire plug up so it doesnt come loose.
Mind you, I just did this on my Hawk this week, and the instructions were pretty simple and clear...
Old 05-05-2019, 06:33 PM   #4
No sir, no instructions on this one. Got it from TX powersports. I'm gona give you instructions a try right now.
Old 05-05-2019, 06:43 PM   #5
Let me take a photo of the directions...I gotta go find them in the shop, brb
Old 05-05-2019, 06:48 PM   #6
Here ya go.
Old 05-05-2019, 07:02 PM   #7
Plugged in the colors, still not getting much. No LED dash but the high beams and right turn signal flash at the same time. Left over purple for 6th I guess, but what about the brown/white?
Old 05-05-2019, 07:07 PM   #8
That brown/white wire plugs into the yellowish one on the bike in that plug. As you see the instructions say the purple one isnt used cause its 6th gear...
Old 05-05-2019, 07:10 PM   #9
This new tach looks like it has no power wire either. .
Old 05-05-2019, 07:14 PM   #10
The power wire is the blue wire with the white line. That one fits in the plug above the green/white one near the carb. It doesnt have an open plug though. You will have to shove it down into the socket that contains the blue/white wire on the bike's harness plug, then tape it up good so it doesnt come loose.
Old 05-05-2019, 07:15 PM   #11
The blue/white wire is located in a plug that has (6 wires..I think) going in and out. Its directly above the green/white one you've been working on, behind the carb...
Old 05-05-2019, 07:46 PM   #12
Alright, thanks man.
Old 05-05-2019, 11:26 PM   #13
Hopefully you get it working properly.
Old 08-20-2019, 06:16 PM   #14
nmann23219   nmann23219 is offline
Did you get it working? I followed this thread exactly and nothing comes on but a turn signal indicator!
Old 04-05-2020, 09:12 PM   #15
shiftclick   shiftclick is offline
shiftclick's Avatar
You have to rewire the new cluster's harness to match the old one. So the two shorter wires in the new harness: on is for the speedometer, the other one is the one you have to rewire.
