Hawk 250 Street Riding
Took the Hawk out for a Saturday morning ride through the twisty roads of South Louisiana swamp to stretch her legs. This is how I get my stress relief from working all week. Took an hour ride and did a quick edit to condensed it down to 20 minutes of the fun stuff. Didn't want any body falling asleep watching. lol. I haven't figured out how I'm going to mount the camera to my street helmet yet so I just clamped it to the Handle bar. I didn't have an external mic so you don't have to listen to me talk. LOL This video is just for the riding pleasure.
It was a cool morning so the camera case started to fog up. I'll just call it special effects. ![]() Enjoy the ride!! The bike has approx. 5,500 miles at this point running the 17/40 tooth sprockets for the streets. Engine Mods are ported and decked head 1 mm. 10:1 compression, Keihin PWK30 carburetor, Decat Ebay CRF230 exhaust, direct ignition coil, NGK DPR8EIX-9 Iridium IX Spark Plug and dual oil coolers.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-01-2019 at 10:59 AM. |
I did the same thing this morning. Left an hour early to go to work and rode the long way around to get there. Great way to start the day.
What top end do you get out of that bike? It looks and sounds much faster than the Storm.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
74 to 76 mph easily. Most of the riding I did that day I was running between 60 and 65 at about 3/4 throttle.
That would be the porting and higher compression at work. Mine sounds very similar.
I do need to repack the muffler. It's starting to get a little loud.
Ditto! Mine didn't last very long lol. Debating doing a fine stainless steel wool around the core with some ceramic cloth behind it. Just to see if I can get it to last longer.
#8 | |
64mph at 8499 rpm is the fastest mine will roll under it's own power. 67 downhill once on the freeway ha. The deck and port work is the only thing I can see different. I need to sell this slow Storm and get the Hawk.
#9 | |
#10 |
You can do the same porting and decking to the storm. Same heads.
#11 |
With the gearing he has it will just get to 64mph a bit faster lol.
#12 |
I have the 46T, 43T and 40T. 46T has the most torque and top end. The other 2 will only just barely break 60 mph.
#13 | |
My current Hawk with the ported head and smaller diameter rear tire (4.6x18 Shinko 700) with what is essentially 17/45 gearing is effectively a 17/47 setup, and it hit 66mph with less than 200 miles on the engine and effectively ran out of gear/rpm.
#14 |
I failed to mention that I'm still running stock knobby tires. On some of those curves I could here a little tire squeal.
![]() ![]() Had a couple of slow pokes that elevated my stress levels on my favorite parts of the ride. ![]() ![]()
#15 |
You are a brave man with those knobbies lol. Good example of what makes a DOT knobby tire what it is though, because a softer non DOT knobby would have probably lost a few shoulder lugs.
