Old 04-21-2019, 03:01 AM   #1
BrandonT   BrandonT is offline
TBR7 dirt tires need suggestions
Hey everyone, thanks in advance for your guidance. I am still learning. So I got a TT TBR7 for riding almost entirely dirt and gravel roads, not street. Just riding in my property, I may as well be riding on grease with as much as I’m slipping on wet grass and loose soil with the stock tires. I live in Western Washington and will likely see a lot of different terrain but lots of exposed roots and rocks. Can someone recommend a moderately priced tire set to suit me? If it matters, I’m a pretty big dude @ 300lbs. Trying to spend less than $100.
Old 04-21-2019, 11:20 AM   #2
Douglass   Douglass is offline
Douglass's Avatar
I put a set of Bridgestone X30 tires on. There is a 40 rebate through Bridgestone that should keep it close to the dollar amount. Make sure to buy new tubes, and rim straps
https://www.rockymountainatvmc.com/t...terrain-tire-p
Old 04-21-2019, 02:29 PM   #3
Thx for your suggestion. I am looking for some right now, but can’t find any in my size. My bike has 90/90-19 front and 110/90-17 rear. I’m not committed to keeping the same size or anything. Just don’t want to order the wrong ones. Obviously the most important is to buy one with the same rim size. But i dunno about the other numbers for compatibility. Also, would upgrading the rims be a good idea?
Old 04-21-2019, 03:33 PM   #4
Douglass's Avatar
I'll check the dimensions when I get home. How much clearance do you have for width and height?
Old 04-22-2019, 12:59 AM   #5
humanbeing's Avatar
Originally Posted by BrandonT View Post
...So I got a TT TBR7 for riding almost entirely dirt and gravel roads, not street. Just riding in my property, I...
http://chinariders.net/showthread.php?t=23484 had some tips if u need 50/50 tires
