04-18-2019, 12:21 AM | #1 |
can some one post a link of a mikuni carbby
I have a Apollo pz30 and want to upgrade to a mikuni carb but cant find one that looks legit
04-18-2019, 12:22 AM | #2 |
its a Apollo 250cc delux
04-18-2019, 12:27 AM | #3 |
This is the mikuni clone i got. I just use real jets from mikuni amd have had zero issue with the carb itself
https://www.amazon.com/gp/aw/d/B07CN...b_b_asin_image |
04-18-2019, 01:26 AM | #4 |
I have the pz30 right now is that a mikuni
04-18-2019, 06:10 AM | #5 | |
04-18-2019, 08:43 AM | #6 |
Pilot Jet
https://jetsrus.com/a_jets_by_carbur...-486_pilot.htm Also main jet, if you want to buy genuine jets and not mess around with the cheap jets that are either mislabled or incorrectly sized. https://jetsrus.com/a_jets_by_carbur...arge_round.htm
04-18-2019, 10:49 AM | #7 |
Yep, love the little Mikuni. Have them on everything (- RX3's). Makes jetting easy and they run superb.
04-18-2019, 12:23 PM | #8 |
If you want a Chinese fake that says Mikuni on the stem and Japan by the bowl search B07CN36W65 on Amazon.. $29.00
That's as close as you'll get to a real Mikuni that is 30mm with 48mm stud holes.. There is actually a real one that has a polished body and plunger choke, but it's extremely hard to find.. I don't know if it's because it's old OEM or what. This is why mine is still rocking a PZ30.. You can also replace the airbox and use a 48mm intake adapter and use any Mikuni you want. |
04-18-2019, 12:38 PM | #9 |
Can you guys post a link to a thread for Pilot jet sizes that are working with the knock off mikuni carb, 120 main, and performance exhaust? Much appreciated!
04-18-2019, 01:56 PM | #10 |
Heres the pilot jet 25 i got
https://www.amazon.com/gp/aw/d/B06XS...b_b_asin_title Main jet 115 https://www.amazon.com/gp/aw/d/B00RR...b_b_asin_title Exhaust https://www.amazon.com/gp/aw/d/B01DO...b_b_asin_title Megadan put the part numbers you should be looking for if you want different sizes of each jets just wanted to show different places to get your hands on them |
04-18-2019, 02:02 PM | #11 | |
Main jet sizes range from 105 to 115 for most bikes. depending on mods. The best combo for an otherwise stock bike is a 25 and a 105. As with all jetting, there are many factors at play so these are not set in stone and your bike and area may require adjustments from there.
04-18-2019, 07:07 PM | #13 | |
Unless you get a mutant hybrid like my PZ30B (pumper) which says Mikuni on the carb body and has the centered carb bore like a mikuni, has 3 bowl screws like a PZ30, takes the odd ball pilot like the stock pz30 carb but uses Mikuni main jets. Gotta love stuff from China.
04-18-2019, 07:46 PM | #14 |
https://www.ebay.com/itm/Hawk-250-Ke...s/303077495104
The Mikuni IMO realy isn't an upgrade of much Look at this set as it isn't expensive and has a lot of stuff in it. |
04-18-2019, 09:15 PM | #15 | |
