Old 01-05-2007, 09:41 AM   #1
red2003   red2003 is offline
Roketa RSX200E, No Tach :~(
Hi guys, my RSX200E didn't come with a tach, but I would like to add one. My manual shows a tach port on the engine case. Do any of the other 200 enduros have a tach with this same engine so I could just buy their parts and put on my bike? Or, better yet, do ANY of the Roketa 200's have a tach?? I tried to find a universal motorcycle tach that was electric and I could just wire it off the coil, but I haven't found one??? Thanks for the help.
Old 01-05-2007, 10:16 AM   #2
DrummerDave   DrummerDave is offline
I think the Lifan 200 has a tach.
Old 01-05-2007, 10:29 AM   #3
I believe the Lifan 200 does, but are they the same engine??
Old 01-05-2007, 10:44 AM   #4
blimpman   blimpman is offline
Send a PM TO EJCYCLES here on China Riders (BRUCE MATTY) He can probably get you the answer.
The destination is merely a by-product of the journey.
'06 KLR650 '06 XT225 '92 XT225 Serow
( MBD.... Multiple Bike Disease...)
Old 01-05-2007, 11:45 AM   #5
Just curious, why do you need a tach? I'm never looking down when I'm riding, except a glance to check my speed when I get up to speed. There's too much to look for ahead of me...like cagers!!
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 01-05-2007, 12:23 PM   #6
I'm a mechanical guy, I guess. I like to know what rpm the engine is turning. I will play around with gearing eventually and it's a good idea to know engine speed vs ground speed.
Old 01-05-2007, 02:49 PM   #7
John22j   John22j is offline
Re: Roketa RSX200E, No Tach :~(
something like this???:
http://www.accessoryinternational.co...egory_Code=Z1R
'20 RPS Magician 250
'06 Hensim (Tierra) DB150-2
'06 X-Treme 70cc pitbike
'02 Kawasaki KX125
Old 01-05-2007, 09:59 PM   #8
fashby   fashby is offline
The tach on my bike is vacuum powered and runs to the carburetor. There isn't any mechanical port on the engine for a tach. I suspect that is the case for most of the Chinese motors.
Viva GY200 California Emissions Jialing/Chonging - Jesus Rules!
Old 01-05-2007, 10:11 PM   #9
frostbite   frostbite is offline
Actually I think it's the opposite. If you're running an 163FML (OHV motor) which is what most of the Lifan's are running then the tach is mechanically (i.e. cable) actuated.
Fashby, your bike appears to be a bit of an anomaly compared to many of the others I've seen (catalytic converter?! EGR Valve! - that's not a China bike, it's a car!!).
Frostbite
"The beatings will continue until moral improves"
Old 01-06-2007, 04:56 AM   #10
CathastrophiX   CathastrophiX is offline
My bike has EGR valve and mechanical tacho, hard to decide if it looks like a anomaly or a car, must probably ask my wife
"Failure is always an option!"
Qingqi QM200GY -06
Old 01-06-2007, 08:05 AM   #11
ejcycles's Avatar
Hi All
Ok lets clear this up, I just saw this post. The American Lifan 200GY-5 has an electronic tachometer, the 200GY-2 has a mechanical or cable operated tachometer. If you have a GY-5 the right engine cover Does Not have a tachometer cable port. If you have a GY-2 the right engine cover Does Have a tachometer cable port. The tachometer cable port is in the right engine case on the front of the cover.
I can't say what other manufactures are doing with the tachometers. They may be set up like this they may not be. There are only two ways to run a tachometer on any vehicle or engine, electronically or mechanically. There are aftermarket tachometers that you can attach a probe around the spark plug wire to run the tachometer, or you can purchase one that will run from a cable for that particular engine. There is no such thing as a vacuum operated tachometer. A tachometer can not tell engine revolution from vacuum. There are two things you can do checking vacuum...check how the valves are operating or synchronize multi-cylinder engine carburetors.
Ride Wild and Fly Like an Eagle! 8O
Bruce
Old 01-06-2007, 07:16 PM   #12
Yup, just like that! Kinda pricey, but Drag Specialties makes good stuff. Thanks for the link
Old 01-06-2007, 08:26 PM   #13
fratermus   fratermus is offline
fratermus's Avatar
Don't think the "no tach" thing is only a Chinese feature. My 2006-model japanese dualsport doesn't have a tach, either.
