Magician 250 frame breaking apart and other problems
Good Afternoon Everyone, so far i made 1100 miles on my 250 Magician and problem arose such as loose screws and leaking air box in which it got fix thanks to you guys
Well that sucks.
Didn't we someone else here with a frame issue on a Magician?
Would the broken bolt and the frame be a (sort of) easy fix? Couldn't he just extract the bolt and then re-thread that hole?
As for the frame, I'd think a welder could take care of that for not a lot of money, no? Is this a Magician thing? Do Hawks have similar issues? I don't imagine you were riding this too hard. |
#4 | |
#5 | |
I most likely gonna do that, im gonna take it to home depot to see if they have a similar size.
As far as the shift lever seal you can get that from CSC. It's the same as the TT250. https://store.cscmotorcycles.com/TT2...p/zt55-122.htm
#8 | |
Since i lost that frame part with the bolt include, does anyone knows the type of bolt that is?
#10 |
class 8.8 - 8m bolt.
#11 |
Thanks again, ill work on it once i get home, hopefully in one piece.
#12 |
Exhaust stud is your fairly standard M8 x 1.25 variety. If you have an ACE Hardware nearby there is a good chance you can get one there, if not most parts stores will likely have one. I would recommend replacing both studs together.
This would be the third Magician owner on here that has posted at least one weld failure/crack, and Motocheez has a video on his as well.
#13 |
200+ lb magcian rider with >6k on the odo, no frame issues. I catch air almost every day I ride when I hit the railroad tracks at 45 or so.
I think the issues may be caused by lack of routine fastener maintenance. Any play creates havoc on this bike quickly. |
#14 |
thats what i was thinking. once something loosens up it wiggles like a muther till it breaks something.
#15 |
I would attempt this OP.. and the heat from the weld will make it come out easier. I just lost both of the nuts that hold the flange down on my last ride. I got both studs out with vice grips. I found that the bolts that held the crate together were the right thread, a little short with a lock washer but I got them tightened down pretty good, dripping with red loctite also
From a CRF250L to a Magician?! Last edited by _skid87; 05-08-2019 at 07:02 AM. |
