Old 04-05-2019, 08:58 PM   #1
mrboo   mrboo is offline
Taotao Rhino 250 valve lash specs
Title says it all what is the spec for valve lash on the rhino this is a 2013 rhino if that matters or not, thanks in advance
Old 04-06-2019, 07:23 AM   #2
Mudflap   Mudflap is offline
I believe most people set them at .003" and .004". I set .002" for both which is what the Lifan CG manual says.
Old 04-06-2019, 08:50 PM   #3
thanks
Old 10-26-2020, 12:32 PM   #4
jwg3bird   jwg3bird is offline
Hi there ,
I’m still searching for a taotaorhino 250 service manual.
Does anybody know where I can get my hands on one, or another model that uses the same engine?
I have replaced The clutch but I’m getting no resistance when I manually try to move lever on side of crank case. Is seems like I’ve forgotten to replace a spacer to bring out the clutch plates to meet the pin that engages the clutch.
Has anyone run into this problem?
Old 10-26-2020, 12:34 PM   #5
Or have access to the service manual so I can retrace my steps????
Thank you ,
John.
Old 10-26-2020, 01:46 PM   #6
Do a search for a factory service manual for a Honda CG125.
Old 10-26-2020, 02:02 PM   #7
storm-english-62ktjam5.pdf
This is the one I downloaded several years ago. If there is a place to upload it to this site I'll be glad to do it. It's about 8.5 megs.
Old 10-26-2020, 05:14 PM   #8
Darth Racer's Avatar
https://josemaco.files.wordpress.com...h-62ktjam5.pdf
When I searched for the PDF name it actually pointed to a thread here at China Riders, with the link.
That manual states 0.003 +/- 0.001 for exhaust and intake.
Old 10-26-2020, 07:50 PM   #9
franque   franque is offline
Originally Posted by jwg3bird View Post
Hi there ,
Make sure you took the bearing and metal piece that connects to the pushrod from the old pressure plate (the part with 4, 5, or 6 bolts on the clutch) and install it.
