Speedo acting strange 2019 Hellcat
Hi,
I went for the longest ride yet today. Forty km each way. I noticed something strange with the speedo. You know when you first turn the bike on and the speedo does its thing? The RPM goes up and down for a couple of seconds and the N indicator flashes etc etc... Well I noticed every once in a while the speedo would do that while I was riding. It did it at least 5 or 6 times each way. I couldn't narrow it down to any speed, RPM or gear. It seemed random. This speedo is stuck in KM/H and i should be getting a new one. But until then I wondered if anyone else had this happen to them or has any idea how to solve it. Thanks Last edited by scoot newb; 03-24-2019 at 07:56 PM. |
#2 | |
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
Thanks. I'll definitely check it out ASAP. I've had all the plastic off and seat off and the connectors I could access were nice and tight. Are the other connectors I can't see without removing the gas tank?
Yes. Don't need to take tank off
Thanks
I got it sorted. Now if only I could make it display in MPH instead of km/h. But it's one of those defective ones. |
#6 | |
Scoot newb, I was looking at another user's guide to recalibrate the speedo: http://www.chinariders.net/showthread.php?t=21714 Well that doesnt work on my 2018 Hellcat but I did find something interesting that may help you. Hold the right button down with the ignition off, then turn the ignition on and it will change from KMH to MPH and back. This is not the directions I was given when I was trying to change my inital dash that was stuck in KMH, but oddly does work for me. Hope it works for you. |
Thanks. I've tried that combination before but no worky on this one.
#8 | |
Im not sure thats what the thrwad the above person posted but thats basically all you can do is try holding down either one of the buttons, one at a time, until something happens. Its possible i got my left button and right button above in my instructions transposed, that is backwards--so try holding down one until something happens or at least 30-45 seconds and if nothing happens then try the other button. I guess I am kind of assuming the Hellcat speedo is like the Grom/Vader speedo though...Oh yes and also hold down the buttons with the key turned to the on position--im not sure if your bike needs to b e not running or runnin g--cant remember but I may have done while bike was running--but my battery power and display was definitley on when I did this today! Hope this helps! Have you figured out how to change the time on yours? if yes that should also be how to get to changing the kph to mph--or its possible the stiffed youwith a KPH only since I think these are sold in other countries where they use KPH...
"Hope for the best, Prepare for the worst, Be pleasantly surprised when the world doesn't fall down on you" "Life's too short not to enjoy it-So's my China Bike!"-Me ![]() |
Yes I can change the time. Some of the 2018 Hellcats have a known issue where the speedos are locked on km/h.
For me, holding the left button (long push) causes the hour to blink, from there, right button cycles hours, left again switches over to minutes, then same, right cycle. Long hold left again sets it, all blinking stops. |
#10 | |
![]() Quote:
Link: https://www.ebay.com/itm/Universal-M...gAAOSwyDFa~U9E Well good luck to yah. All I can say is like I said before keep trying button combos--before I knew how to work mine I was trying to hold one either for just a second or for a long time before pushing the other either briefly or also holding it down while still holding the first one--all to no avail. But basically I tried a lot of the possible button combos before I figured mine out. I guess a cell phone holder for gps could also work--I have seen a person blog with a Hawk and NO gauge cluster use an attached cell phone speedo pass Vermont Motor Vehicle Department Inspections, although they would plate just about anything in Vermont whether they see it or not, whether you live there or not they just want the $$ ![]()
#11 |
Tao Tao supposedly will replace the defective ones.
https://www.chinariders.net/showthread.php?t=22010 The problem is they don't return phone calls or answer e-mail. |
