Old 03-15-2019, 11:54 PM   #1
Ski_rush   Ski_rush is offline
Close...but not quite
So, I got the new battery from Amazon today. It arrived fully charged and I bolted it up as soon as I got home. There is some progress; the engine is turning over and trying to start. So, I likely don't have a short, or a loose connection, or a bad starter solenoid, correct?
1. Gas was on.
2. Bike is in Neutral, but I also tried with clutch in, just to be sure.
3. You don't see this in the video, but I also tried rolling the throttle halfway and then all the way and got pretty much the same result. The sound changed a little (actually thought it might go for a second).
4. You don't see this in the video either, but I also tried with choke off, halfway, and fully on. Same result and no change whatsoever in the sound of the cranking.
Please help me get this started. I have a feeling that you all are going to suggest a carb and/or jet change...
Thanks,
Old 03-16-2019, 12:09 AM   #2
tarote9025   tarote9025 is offline
Is the fuel turned on i was wrenching on something the other day and almost took the carb out before i remembered to turn it back on simple stuff usually gets overlooked in my experience you could also just crank the idle screw down until it cranks and back it out after had to do it on my buddies bike about a week ago after watching him kick 30 times lol
Old 03-16-2019, 12:12 AM   #3
Jeff Richardson   Jeff Richardson is offline
Jeff Richardson's Avatar
OK, so it's new and you've never run it. Already found a defective battery. Man, I'd be super pissed right now. Since you have a nice crank might else well pop the plug and check the spark. Then grab the ether next. I don't know how easy or difficult it is to get to the intake on those Apollos. Hawk is simple to unclamp at carb. Worst case you have easy access to the airbox with seat off. Also you should be smelling gas. Definitely want to make sure it's getting to the carb.
Old 03-16-2019, 12:17 AM   #4
1. I forgot to mention that I have a brand new NGK spark plug in it right now.
2. Yes, I smell a little gas.
3. Yes, I'm pissed and want to drop kick this thing off a cliff.
Old 03-16-2019, 12:19 AM   #5
Brand new plug but is it getting good spark when you ground it to the head?
Old 03-16-2019, 12:24 AM   #6
By grounding to the head, do you mean touching the nut/bolt of the plug to the cylinder head of the engine? If so, I didn't try that yet. Is that what you meant?
Old 03-16-2019, 12:28 AM   #7
Yes ground the tip with it plugged in while cranking. Just make sure not to pull it away while cranking or you'll get a nice little jolt. 😁
Old 03-16-2019, 01:35 AM   #8
There is no spark. I did as you suggested. Took the plug out, and reconnected the cable and made sure it was pushed all the way in. No spark.
I tried both the NGK plug that I got as a "free gift" from the seller and the "NGK" plug that came in the bike. No spark.
I'm guessing that this means there's a much bigger and more significant problem with the bike...am I right?
Old 03-16-2019, 01:43 AM   #9
NzBrakelathes's Avatar
Check wires at CDI and coil to be sure its not broken loose or looks like on but not actually on.
Check kill switch check ignition switch to see if the wries are no somehow connected.
Check the blue/white wire and green/white wire from stator area that they are actually connected etc
Old 03-16-2019, 01:48 AM   #10
And, what would it mean if those wires are all connected just fine?
Old 03-16-2019, 02:35 AM   #11
The bottom line is that I believe that I have a lemon that won’t start. And, to make matters worse, I unknowingly purchased it from Manny. I didn’t know it at the time.
I am tired of dropping time and money into this POS that won’t start. I bought a new battery, got excited, hooked it up, only to find it has no spark. Things are going from bad to worse. I can’t just eat $1700 to chalk it up to lesson learned. I don’t have that kind of money to be able to do that.
I contacted the bank. They opened a dispute, but they also give the seller a chance to refute my claims and make his own claims. I’m sure Manny has dealt with this issue before and is practiced at it. It’s my word against his and the bank decides the result.
Anyone have tips and advice on handling the dispute with the bank and showing evidence?
If the bank decides in his favor, I’m left with a paperweight sitting in the garage that cost me $1700. I’m sure that’s going to go over splendidly with the wife. I’ll never hear the end of that.
Or, I can offer it up for sale here. I’m sure some will try to kick me when I’m down with their offers too. The joy and excitement of owning this bike, and thinking of riding off road with my boys are all dead.
Old 03-16-2019, 07:21 AM   #12
Did your bike come with a remote start? If so try starting it with it. Could be something with the alarm system killing the spark.
2004 Honda ST 1300
Old 03-16-2019, 07:57 AM   #13
pete   pete is offline
pete's Avatar
I think the starter could be robbing most of the power not
leaving enough for the spark... weak or no spark..
some bike starter just barely crank the motor fast enough to start it..
I know you have a new battery.... but not all are created equal..
just don't buy cheap battery's .. " Yuasa "
kick it.. push it... try engine start...
once started and run for a few minute the issue could go away...
I have rebuilt motors... they would not start with out a push...
but once started they were perfect from then on..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 03-16-2019, 08:12 AM   #14
Hancadam   Hancadam is offline
I know it's frustrating, and confusing tracking down electrical issues, but this is probably something very simple and cheap. Finding what that simple problem is the hard part. If youre not getting spark, it can a host of things.
Possible problems areas to check:
Bad ground
Popped fuse
Kill switch (if you have one)
Bad cdi
Battery (I know you replaced, but points above are valid)
Loose connection
Bad ignition coil or boot
Etc...
These are the kind of risk and challenges we accept when buying these bikes. Some of use get very lucky, others not. But when there are issues like this with Chinese bikes, it's mostly up to the buyer to accept in my opinion. At least I assume me working to fix it is the most palatable solution over trying to get help from the "dealer" (like you said, especially Manny).
Where are you located? Maybe one of us are close to you. This is something we can collectively resolve. Point is, the problem/solution is likely very cheap or free to fix, once found.
Old 03-16-2019, 08:22 AM   #15
It may also be worth confirming no spark means no shock from the plug. The redneck way of testing that is to hold the spark plug in your hand will turning the bike over and seeing if it shocks you. I've had to do that several times diagnosing no spark issues on 3 wheelers.
