03-08-2019, 11:15 AM | #1 |
Hawk gas gauge not working.
And yes I did try to search the forums first and it said the word gas is either too short or too long so it brought a bunch of threads about gauge clusters.
I hadn't really noticed before today but I've got the tank about half full and the gauge hasn't budged off the E. Just wondering if this is a common thing or maybe a wire is bad etc. I'm not even really that worried about it because most bikes don't have them, but.. |
03-08-2019, 11:24 AM | #2 |
Pull the tank and check the wire and connector for breaks or bad connections. I recently had to solder the connection on the sending unit. It's just crimped on there and the slightest bit of corrosion will make it not work.
Here a thread that someone else posted and where I got the info from to fix mine. http://www.chinariders.net/showthrea...t=sending+unit
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-08-2019 at 11:40 AM. Reason: Added link to thread |
03-08-2019, 12:13 PM | #4 |
I remember humanbeing saying the float would putout O - 100 Ohm's empty to full on the tank sensor's output. Check that with a multimeter !
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
03-11-2019, 06:07 PM | #6 |
and it has metal ear on each side that the arm stops on that you can bend till you get the correct readings. i remember 10-90 but either would probably be close enough.
03-11-2019, 07:14 PM | #7 |
Is it normal for the gauge to bounce around like crazy while riding?
03-11-2019, 10:02 PM | #8 |
Ya, especially if your tank is half full. I thought about adding a 5k Ohm resister to slow the effect. I could use a Radio Shack now.
03-14-2019, 07:35 PM | #9 |
I pulled my sending unit apart and took the slop out of the arm that caused a connection break in the pontentiometer arm. Works perfectly and reliably now. http://www.chinariders.net/showthread.php?t=23159
