02-27-2019, 03:58 PM | #2 |
Just curious why you wanted to upgrade the carb. Are you having issues with it? I have an 2018 Apollo Commander, and it runs great with the stock carb. Not sure if it would be an upgrade, but check into a PZ22 Keihin Carb. I'm pretty sure it's a knock off, but it seems like a good quality. You might loose the choke lever function on the handle bars if equipped. Here's a link, it's stamped Keihin, but listed as unbranded. This is what it looks like though.
https://www.ebay.com/itm/22mm-Cable-...frcectupt=true Douglass |
02-27-2019, 07:17 PM | #3 |
just looking for other options. after the rhino carb swap, the engine is way more responsive and smoother in idle. was hoping to see more life come out of the smaller engine with an upgraded carb
02-28-2019, 01:03 AM | #4 |
You could replace the rear sprocket. I went up to a 41 or 42 tooth rear sprocket.
03-19-2019, 02:57 PM | #5 |
Was You able to use factory intake manifold? If not what manifold worked.
