Carburetor question
On the hawk. I have a Mikuni carburetor. What Jets come on that. Should I change over to 115 jet. My throttle at top end. does not feel like it have any more speed to it.
If you just bought the carb, and it is the Mikuni VM26 variety... they are usually shipped with a 20 slow/pilot jet and a 100 main jet
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
Mikuni clone comes with 20 pilot and 100 main...as far a what you should change to depends on a lot of factors, the altitude you live at, modifications that you have done like exhaust or air filter etc,. I run with the stock pilot and a 115 main and I had to move the needle up one notch to lean the idle out a little. Each bike is different so you have to play around with it till you get the right set up.
For reference, I took the cat out of my header, NGK plug, opened airbox, and with the 20 pilot and 120 main, needle clip on the second notch from the top; it runs perfect. I have a 40 tooth rear sprocket and the highest I've hit so far is 62 mph (Verified by GPS and digital dash).
#5 | |
I would also suggest opening the carburetor to verify what jets you have. Lately some versions of the "Mikuni" have come with a pilot jet stamped as a "40", but as a member on here verified it's orifice size is closer to that of a 25 or 27.5 Mikuni VM28/486, meaning it is actually a Keihin 40 sized jet much like the stock carburetor.
As ARH stated, a list of modifications will go a long way as well.
I am using a pod air filter, and aftermarket Muffler.
If you want to consider the stock carb heres my kit and flexible on jettting etc.
https://www.ebay.com/itm/303077495104 I have a few things for the Hawk etc and will be listing more after I confirm more fitment issues |
