Old 02-25-2019, 03:25 PM   #1
schleppy   schleppy is offline
TT250: If you are looking for main jets from Amazon, I found them
I recently picked up this jet kit from Amazon:
And the jets work perfectly with the stock OEM carb. I went from the 105 to a 110, and it is substantially better than stock. I also moved the needle up one notch, and adjusted the idle mix screw out 1.5 turns. I'm at sea level.
Hoping this helps another TT250 owner.
