02-18-2019, 02:29 PM | #1 |
Adjustable brake and clutch levers for the TT250?
Does anyone have links to a set of adjustable brake and clutch levers that fit the TT250? The stock levers are in an odd position for me.
Thanks! |
02-18-2019, 02:43 PM | #2 |
I've heard Honda grom levers will drop in, I've got a set like these on my Hawk and there a huge improvement. They do get a little tight under the brush guards. Ebay and Amazon have loads of them.
https://www.ebay.com/itm/For-HONDA-G...A91TEA&vxp=mtr
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
02-18-2019, 02:50 PM | #3 |
I replaced everything with these because my master cylinder was hanging up and the brake light would stay on. Work much better than stock. https://www.ebay.com/itm/Universal-M...c855%7Ciid%3A1
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-18-2019 at 05:00 PM. |
02-18-2019, 02:51 PM | #4 | |
02-18-2019, 03:04 PM | #5 |
It's about the same but the lever feels much better now that I can adjust it. I can grab the lever with two fingers much easier than before.
02-24-2019, 02:39 PM | #6 |
So I ended up buying these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The brake lever fit perfectly (awesome!), but the clutch lever isn't even remotely close. Has anyone found a brake lever that drops right in? |
02-24-2019, 06:36 PM | #7 | ||
