Old 02-10-2019, 11:18 AM   #1
davisbm2   davisbm2 is offline
FIns
Hey
Old 02-10-2019, 11:24 AM   #2
BBOWL10   BBOWL10 is offline
BBOWL10's Avatar
It looks like it could be. I would clean up the engine thoroughly and keep an eye on it to see if it reappears and if it does how long it takes to reappear. Then go from there. Maybe it just came from the tire kicking up something onto the engine. Grease or oil?
2017 Kawasaki Versys 650 - Seat Concepts Seat, Moto Werk Foot Peg Lowering Blocks and Highway Pegs, MadStad Windshield, SW Motech Rear Rack, Givi Handguards and Rear Fender Hugger, Polaris Series Regulator Mod, Denali Sound Bomb Air Horn, SHAD Luggage
2018 RPS Hawk 250 - CRF230 Exhaust, Mikuni Clone Carb, LED Headlight and Tail Light, Pod Air Filter, Generic Hand Guards, Volt Meter/USB Port, Grip Puppy Grip Covers, 45 Tooth Rear Sprocket, Shinko 244 Tires with IRC HD Tubes, AGM/SLA Battery
Old 02-10-2019, 01:02 PM   #3
Not super common, but not unusual. Start by checking the head bolt torque. I use the most current CG125 head torque specs. 24ft-lbs for the 4 main nuts under the valve cover and 20ftlbs for the outer bolt on the left side of the head.
Clean it up as BBOWL10 suggests afterward and see if the oil returns. If so, a new head gasket isn't very expensive and very easy to do.
Old 02-11-2019, 10:08 PM   #4
512customs   512customs is offline
512customs's Avatar
Looks just like a Harley head gasket! Haha
Toys:
2017 Hawk 250 (new in 2019)
1999 Softail, Ultima frame, s&s 113” @ 129rwhp
2005 Honda trx450r full mx build
1986 Honda trx250r xc build on race gas
1998 Kawasaki kx250
1995 Polaris xplorer 400 4x4
1997 Jeep Wrangler 3.5” on 33s
Old 02-12-2019, 08:55 AM   #5
If you pull the head make sure to check if the o-ring for the oil passageway isn't split, smashed or missing.
2004 Honda ST 1300
Old 02-13-2019, 06:30 AM   #6
jimwildman   jimwildman is offline
jimwildman's Avatar
also make sure the breather is clear, pressure building in the crankcase will get past many seals.
500cc Hawk Project http://www.chinariders.net/showthrea...372#post281372
Old 02-13-2019, 10:04 AM   #7
When I was a kid, all my four strokes (Honda's) did this. I just kept on riding and Gunk'd them once in a while.
Old 02-14-2019, 02:04 PM   #8
DualSport   DualSport is offline
If that o-ring cracks or changes shape in any way the oil from the back-right cylinder stud will completely strip the head gasket of any material. If the cylinder stud bolts aren't equally torqued at the pounds listed in the CG 250 repair manual you'll also get this..
Get gasket kits off Google shopping or AliExpress. RPS and all the dealers who are basically drop-shippers for them want a fifth what they sale a new engine for a single head gasket..
