Old 01-26-2019, 10:47 AM   #1
Chineeske   Chineeske is offline
Decided to upgrade my Orion Apollo 250 with a Honda XR250R engine
I have thought about this well, about the pro's and cons but I just can't sell my Orion... I really do like the looks of it, and despite it's Chinese made (so it can have some major upgrades here and there) it is a brand new bike...
Thing is, is that I don't like the engine (as in no power) in the dirt.
So I have decided to upgrade my Apollo with a Honda 250XR engine which happens to lay around in my shed.
This afternoon I made a small start with it:
The airbox is a pain to remove... it will only leave it's place when the subframe is unbolted
Removed the wire harness and subframe
20 minutes later and you have some extra rubbish laying around in the shed
Although I was quite happy about the build quality of the Apollo when I bought it, I have found some small issues here and there...
And that is the quality of the paint of the frame, subframe and suspension...
Some tiny rubbing already causing this:
Hose rubbing
Some rust at the swingarm, where the mudflap sits
Where the side plastic is bolted to the tank, also some rubbing marks
Also the subframe isn't painted by a high quality painter, as it seems he/she missed some spots causing some rust
Guess I will repaint it, I'll see that later on
But besides the paint, the frame itself needs some work too to handle this lovely engine:
On the outside the frame looks beefy right?
But see what's inside this "beefy" looking frame...
Jep... much air here... or hollow spaces if you would like to call it that way...
So the Apollo needs some frame strenghtening here and there, I'll do that by welding some steel plates in and some bracing.
To be continued....
Old 01-26-2019, 11:16 AM   #2
I am looking forward to seeing how this progresses.
Old 01-26-2019, 11:22 AM   #3
PaiN   PaiN is offline
PaiN's Avatar
What a cool project....I'll definitely be watching how it comes together.
From the looks of your shop, seems like you have the tools and know-how to make this happen.
"Talking about living life is nice and all....but a motorcycle is a tool to actually do it." -me
You Tube: PaiN's Rides
Currently riding the hell out of my 2013 Victory Cross Country.
Old 01-26-2019, 11:25 AM   #4
Landsvw   Landsvw is offline
Landsvw's Avatar
That bike has a nicely designed frame from what I can see. Is it a steel welded copy of a Japanese aluminum frame?
Can’t wait to see how it turns out myself!
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 01-26-2019, 11:27 AM   #5
Landsvw's Avatar
Something like this one maybe?
https://oregoncoast.craigslist.org/m...798129996.html
1975 Corvette
2017 Chevy Bolt
Old 01-26-2019, 12:02 PM   #6
Thanks!
I do have some nice tools but I am just a amateur mechanic In daily live I am just a sales manager in the food business who loves to work with his hands.
But this little project will work out just fine, I have dealt with bigger and more complicated motorcycle projects in the past
For example this little bike:
An old Honda Transalp 600
A couple of weeks later, a bit more modern looking and the engine got a complete engine overhaul. Same bike, just a bit different.
I just like playing around with metal
Edit; the Transalp frame has been modified to accomodate the AT swingarm with the Ohlins shock. Also the frame itself has been modified and welded to place to CRF rear fender. The frontforks are from a XR.
Old 01-26-2019, 12:04 PM   #7
Thanks!
It's steel for sure, but it's pressed metal. I do like the lines of the frame!
Old 01-26-2019, 12:09 PM   #8
Nearly... as the center frame bars are not so steep on the Orion but sure it's close!
Old 01-26-2019, 12:17 PM   #9
Landsvw's Avatar
Originally Posted by Chineeske View Post
Thanks!
Man oh man, a v-twin dual sport Honda. There’s no ‘heart’ icon!
I do a lot of fabricating and goofing around that way too, but nothing as clean as that bike. Thanks for sharing!
1975 Corvette
2017 Chevy Bolt
Old 01-26-2019, 01:16 PM   #10
Thank you for your kind compliment!
Old 01-26-2019, 01:41 PM   #11
DualSport   DualSport is offline
One of the nicest China frames I've seen. I had an Apollo once but it was tubular taiwanese steel like the RPS..
I'm in the process of putting XR 650L controls and throttle on my Magician and am looking for a Honda CDI and coil replacement too..
Old 01-29-2019, 01:38 PM   #12
Done a more
I thought that putting a XR engine into the Orion would be a piece of cake...
But the truth is, is that the frame needs some serious welding and custom fabrication
First fitting
None of the holes match...
So decided to start cutting here and there
Almost there
Chain seems straight...
But no worries, as it's certainly not a straight fit...
I had used to lower engine mounting points as reference... But wrong guess, as it's certainly not welded straight in the Chinese factory...
So... it will be serious grinding and welding!
Old 01-29-2019, 03:52 PM   #13
Let me start off by saying that you are taking some amazing pictures showing the detail of your fitment issues.
I am not surprised that most of the mount points are not going to work. The XR engine is slightly different in the mount locations than the CG engine family. That said, it does at least fit within the frame for the most part. In the realms of fabrication, making some new brackets aren't all that bad.
Old 01-29-2019, 04:45 PM   #14
Dan, that's correct, it fits into the frame and that was the biggest challenge
Old 01-29-2019, 08:25 PM   #15
roundhouse   roundhouse is offline
roundhouse's Avatar
What a great thread. I am smiling looking at all the pics. then I frown because i have the mechanical skills of a purple headed sea slug..........THEY DON'T HAVE HANDS!
