Light bar accessories what do u guys got
Ive been looking into putting a light bar and a usb charger on my tt250 any suggestions what do u guys run?
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
I ran a separate switch and relay harness that I cut down to work on my bike for a pair of spot lights. The switch was surprisingly very well built and the harness was of decent quality for the price. I cut the switch from the harness off and had to hack a few feet of wire from it and figure out the differences in switch to harness wire colors as they are different, but it worked out well.
Harness. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Switch. https://www.amazon.com/dp/B0195V8G4Q..._t3_B0171G7E8G I use it to run a pair of small cheap round spot lights. They haven't been too bad to this point. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 As far as a USB charger, I just added a USB/Voltage handlebar mount with an SAE plug end that lets me plug it into my battery tender harness when am not hooked up to my charger. https://www.amazon.com/GoldenHawk-Wa...+charger&psc=1
#3 | |
Connect to say brake switch black wire that’s ign +and ground to anything metal It won’t need a relay it’s tiny Big lights relay would better then burning out light switch |
I run the same lights on Q that Megadan linked. Nice units for the money. Very bright. I just mounted a separate switch. Made some small brackets and mounted them to my lower tree.
