Old 01-22-2019, 12:15 AM   #1
chas1956   chas1956 is offline
How to set valves onTaoTao ATA250D
Alto I've had ATV's I've never worked on them so I'm need some help here. Can some help me set the valves on my Taotao? I am have issues with starting it and the loud noise it makes almost lie it's trying to pop back through the carb but I don't think that's what is happening. I had someone a few months back tell me to adjust the valves but I don't think he told me the correct way so I'm not ashamed to ask for help because if you don't ask you never know. I had another say it was the starter drive clutch that was bad by letting the motor try to turn backward while trying to start. Thanks for any help you can offer.
Old 01-22-2019, 06:49 AM   #2
Mudflap   Mudflap is offline
The starter clutches on the ATA250D engines do make the squealing sound but it doesn't affect operation. There are videos on line that have step by step instructions on adjusting valves on a CG engine. 15 minute job after you do it a few times.
Old 01-22-2019, 07:47 AM   #3
Although this is for a Hawk250 it is the same process and settings.
2004 Honda ST 1300
Old 01-22-2019, 09:22 AM   #4
PANDEMIC   PANDEMIC is offline
That is the same video I used
Old 01-22-2019, 01:35 PM   #5
Thanks for helping me out on setting valves.
Everything looks ok on the starter gears. I need to get a new starter because mine stopped working. Any suggestions on where to buy from?
Old 01-22-2019, 03:00 PM   #6
Douglass   Douglass is offline
Douglass's Avatar
i believe this is TaoTao's own parts supply out of Texas. I just ordered from them On Sunday the Jan 20th, and the parts shipped yesterday. Should be here 1/24.
www.partskit.com
https://partskit.com/#/product/searc...c=0586&vn=ATVs
Old 01-22-2019, 09:18 PM   #7
www.partskit.com
I didn't see a ATA250D listed ??
Old 01-22-2019, 09:23 PM   #8
NzBrakelathes's Avatar
This tool set would prob help you with valve jobs n oil changes etc
Worth a look
https://rover.ebay.com/rover/0/0/0?m...2F303036147713
I should mention that I am in fact the seller etc.
Old 01-22-2019, 10:30 PM   #9
Skibrat   Skibrat is offline
Very helpful tool assembly
2018 BMS CRP 250, 1986 Yamaha 350xt
Old 01-23-2019, 05:12 AM   #10
Engine and many other parts are the same as the Rhino 250.
Old 01-23-2019, 04:36 PM   #11
Before getting a new starter, I would suggest you bench test the one you have. You may find that it's fine and that you have another issue. If you do find that the starter is bad, ordering one from Amazon or EBay will be easier than tracking one down by the ATV it goes to. There are ones that fit a wide range of vehicles. You just have to match up the bolt patterns.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 01-28-2019, 09:30 PM   #12
Well the starter checked out ok but it seems I have a gear/gears that are wore down to where it's trying to work like it should but it seem to be slipping. If you loosen the starter and lift and twist it then it does better but still slips. By just looking at the gears they look good and don't appear to be stripped. I haven't got the Starter clutch off yet but it seems to be working like it's supposed to . If anyone has ideas or has had this issue I would like to know what you did to fix it.
Thanks
