Hawk 250
I have my current motorcycle up for sale and hope will be able to get a hawk when/ if sell it. I've read just about everything there is to know about it. I was just watching a motocheez video about changing the fork oil and he mentioned about the shrader valve in some bikes. Has anyone done this to a hawk by drilling and tapping nut at top. Also is there still an issue with the rear sprockets on these. I already have a list of neccesitys and some goodies. For the most part I know what I'm getting into and I have had a china bike before.
As for the shrader valve, it’s been done I’ve seen pictures but can’t remember who did it. But you can probably get by just fine with thicker fork oil and making some spacers to go in them (megadan has great info on that). And as far as the sprocket, straight out of the crate, my stock sprocket did have some wiggle to it. After installing the JT sprocket, and torquing down the nuts, the sprocket was absolutely solid.
Toys: 2017 Hawk 250 (new in 2019) 1999 Softail, Ultima frame, s&s 113” @ 129rwhp 2005 Honda trx450r full mx build 1986 Honda trx250r xc build on race gas 1998 Kawasaki kx250 1995 Polaris xplorer 400 4x4 1997 Jeep Wrangler 3.5” on 33s |
#3 | |
#4 | |
I also put 15 weight fork oil in the forks and added an additional 8 mm of washers in each fork for the preload. It seems to work about as well as can be expected for what it is. It is still not going to be high performance by any means but is fine for road and light trail use.
2017 Kawasaki Versys 650 - Seat Concepts Seat, Moto Werk Foot Peg Lowering Blocks and Highway Pegs, MadStad Windshield, SW Motech Rear Rack, Givi Handguards and Rear Fender Hugger, Polaris Series Regulator Mod, Denali Sound Bomb Air Horn, SHAD Luggage 2018 RPS Hawk 250 - CRF230 Exhaust, Mikuni Clone Carb, LED Headlight and Tail Light, Pod Air Filter, Generic Hand Guards, Volt Meter/USB Port, Grip Puppy Grip Covers, 45 Tooth Rear Sprocket, Shinko 244 Tires with IRC HD Tubes, AGM/SLA Battery ![]() |
I already have an idea how I'm going to set bike up to suit me plus plan on regearing with 17/45 sprockets just didnt know if they fixed it yet.
