Old 01-16-2019, 05:03 PM   #1
Sir kayakalot   Sir kayakalot is offline
Sir kayakalot's Avatar
Hawk battery
Well, after almost 3 years, my original battery that came on my Hawk has finally died. I haven’t seen any recent discussions on replacement batteries. What do you guys recommend?
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs
Old 01-16-2019, 05:12 PM   #2
I just replaced mine a few weeks ago after 2 years and 3 months with this one. https://www.amazon.com/dp/B011599JEC...v_ov_lig_dp_it
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 01-16-2019, 05:42 PM   #3
Thanks Jerry. The price is sure good on that one but I’m concerned about it only having 130CCA. Does it crank your Hawk sufficiently? I know how thrifty you are on your Hawk so I knew you’d link me to the cheapest one available lol.
Old 01-16-2019, 06:00 PM   #4
It spends it better than the original battery did.
2004 Honda ST 1300
Old 01-16-2019, 11:36 PM   #5
The original battery was rated around 120-130cca iirc. These tiny little motors don't need much to turn over.
I have this little guy in my Hawk. They went up in price since I ordered mine last year. Almost 40% higher now. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
An AGM battery from Battery Tender that will work. https://www.amazon.com/dp/B07HNTCLKY...detail_9?psc=1
A lithium iron phosphate battery with restart function that works. A bit pricey, but most lithiums are. https://www.amazon.com/dp/B079V1B82Y..._t2_B00VM7P0VY
If you are feeling particularly rich.... https://www.amazon.com/Antigravity-B...ords=AG-ytz7-8
Old 01-17-2019, 12:01 AM   #6
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Is there a minimum on Amp hours? I see a range of 4AH to 9AH a lot. Any benefit?
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 01-17-2019, 12:06 AM   #7
I would recommend at least 6. That is sufficient for these bikes.
EDIT I should state that 6 is a personal preference. You could go as low as 3 or 4 as long as you aren't powering a lot of accessories such as extra lights, chargers, etc.
Old 01-17-2019, 08:15 AM   #8
humanbeing's Avatar
The original battery was rated around 120-130cca iirc...
The stock wet 12N6.5 can't reach those figure. Typical is ~60cca http://www.leoch.com/pdf/sli/motorcy.../12N6.5-3B.pdf CCA: a measurement of the number of amps a battery can deliver at 0 ° F for 30 seconds and not drop below 7.2 volts. CA: cranking amps measured at 32 degrees F aka marine cranking amps (MCA) are more useful in m/c. Riding a bike when there's ice/ snow...
http://mxjidian.com/index.php?s=/Product/pinfo/ptid/176 tells what a starter motor draws normally...
Old 01-17-2019, 08:40 AM   #9
Thank you for the correction. It's nice to see actual specs on the original battery type. Basically, anything off the shelf that is the same size, or even smaller, is a huge upgrade.
Old 01-17-2019, 02:29 PM   #10
Thanks for all the info guys, got one ordered off Amazon.
Old 01-17-2019, 02:38 PM   #11
I think we got our bikes around the same time. We must of gotten the good batteries on ours. I was surprised mine lasted over two years. From what most on here reported they were lucky they got a year out of theirs.
2004 Honda ST 1300
Old 01-17-2019, 06:08 PM   #12
Yes Jerry you are correct. After looking back it’s more like 2 years and 4 months. We did get them pretty close to the same time. I just thought my battery lasted so long because I got the Green Hawk and we all know they are the fastest and have the best batteries, hehe! I never really treated my battery special on this bike. No battery tender, never had to charge it, nothing. Just got lucky and got one of the good ones, like you
Old 01-17-2019, 08:51 PM   #13
Same here. I just checked the fluid level every once and a while. It just quit one day but worked fine the day before. A t first I thought it was a bad connection.
2004 Honda ST 1300
