Vader/Boom 125cc Upgrades..?
Hey y’all wanted to come on and get some advice in regards to upgrading a new Vader 125cc bike I got. Only thing I’ve done so far is put in a new larger 17T front sprocket. It’s been a nice upgrade, no overall change in my top speed but I can take 1st 2nd and 3rd gear to higher speeds before having to shift since I put it in.
My question is how can I get more top end speed? Go with a larger rear sprocket, upgrade the carb? Any suggestions or advice would be greatly appreciated.. |
Upgrade carb forsure and I would do the exhaust too. Tires are a big improvement as well. Will definitely make bike safer. I have done all of those mods and have woken up the bike a good amount. Next for me will be the zs190 swap. Let the modding begin.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
You will want to get another carb and definitely a pipe too. ,and a Uni style air filter of course . If the bike has less than 500 miles on it , be aware that these things really do pick up on performance once they get 300-500 miles on them and everything has a chance to seat / seal / wear in , my Vader easily picked up 5mph on the top from when it was new .
If you have already put a 17 tooth front on, i 'd add the carb, pipe, and filter first and wait on the 500 mile break in mark before i changed the rear sprocket - I'm not saying their isn't a tad more top end speed to be had by changing the rear gear ,but depending on your size and weight it's likely to be minimal , the issue being the final drive gearing will get so high that you are going to run out of horsepower required to pull those real high geared sprockets. There are several threads on the Forum about what carb works and what exhausts will fit without major problems ,so take your time and read up on it so you only spend the money once . All that said, welcome to the Forum , Chinariders has a great community and always try to help in any way possible.
I haven't touched my carb and I have 2k miles on mine so far. I changed the pipe to open it up a little and it helped my top end speed. I have a maxxis knobby on the rear and changed the front sprocket. I also put pro taper micro bars on because I thought the stock ones were really awkward.
2002 Harley Davidson XL883R 2012 Yamaha FZ6 2022 Hawk 250 2002 Yamaha R6 *sold* Vader 125cc *sold after owning for many years* 1997 Jeep Wrangler *sold due to frame rot* |
Mikuni VM22 26mm Carb Carburetor PZ26 125cc 140cc Fit For Honda Taotao Lifan Zongs... https://www.amazon.com/dp/B07987XD5H..._HQPoCbV0F4NR6
How’s this for a carb? |
That is exactly the carb you want ,make sure to order a jet kit also ,the page that link takes you to shows a wingsmoto jet kit on it .,down near the bottom.
You can use the stock intake but a matched aftermarket would be marginally better ,and of course get a high flow air filter. We are all running the VM22 ,and once dialed in it is a great carb. Do you know if your Vader is the Gen1 Model or the Gen2? Mine is the Gen2 version and it is slightly more difficult to install some of the mods on due to the bodywork /plastics covering up more of the access points compared to the Gen1 but it is still completely doable, it would help with mods though if I knew whether yours was Gen1 or Gen2. Thanks man !
The bike is brand new I’m not sure which gen..
We all like pic's
Take a look at this thread:
http://chinariders.net/showthread.php?t=22514 That should clear up the easy mods on the bike. Not so easy mods (aka more than just a screwdriver and wrench): 1. lightweight oil spinner. Apparently on the Groms, people lathe them down to reduce the overall rotational mass. No reason why the clones couldn't have the same thing done. 2. Bore kit. Easy to do, but you'll need to figure out if you have a 13 mm wrist pin or 14 mm. A shop/store I talked to said that the clones are relatively new, so they should be a 13 mm wrist pin. I haven't checked mine yet so no idea if this is true or not. But... best bang for your buck is going to the ZS190cc or the Daytona Anima 190cc (both same engine - supposedly made in the same factory). |
#10 |
#13 |
What air filter should I go with along with the Mikuni VM22 Carb?
#15 |
Also another quick question. Anyone have issues with the stock headlight flickering a lot? I took the bike into the dealer and they found no wiring issues, could it be a cheap bulb issue?
