12-12-2018, 06:28 PM | #1 |
Calling on the ChinaRiders Think Tank (what chain?)
I just got in new JT front and rear sprockets and I plan on applying a good chain to it when I figure out what I'll stick with. I'll reveal the ratio and sprocket sizes and why I chose this path in the next video.
I also plan on including the RPS Hawk stock and preferred upgraded ratios to cover all the new "Hawksters" that follow our forums now and in the future, So all you Vet Hawk owners (Moderators included) please post what setup and why and I'll be sure and add a nod to you and your valuable experience to the Video! I'm gonna need about a 130 link chain with possibly o-rings or a high tensile strength to last a good while. I'm sticking with the 428 but could go to 520 much later after I see how a good 428 set up lasts. Price can go between $25 to $75 depending if it's worth the jump in price. I'd prefer everyone to kinda come to a unanimous agreement on a all-a-round GTG chain at a fair price for any bike. I really don't feel like guessing and lay my trust in the awesome members here at ChinaRiders!
12-12-2018, 06:54 PM | #2 | |
I ordered the JT 428 heavy duty 128 links for $19 with shipping, have logged over 3,000 miles on the stock chain with no ill signs so I'm waiting awhile to put the JT on until I do all my performance mods in February. Did 2 hours of dirt today, it's a good quality stock chain on the Storms. |
12-12-2018, 07:02 PM | #3 |
Thanks ChipToothy, it's noted. O-ring or non O-ring? I really want a general consensus on these chains or if it really even matters much.
12-12-2018, 07:20 PM | #5 |
I actually have that chain saved but wasn't wanting to say. Thank you Mudflap it is noted, I was hoping that one would make the list.
12-12-2018, 07:28 PM | #6 | |
I'm not sure anyone makes an ORing in 428?, I didn't see any in my shopping around. My JT is the Black Steel HDR2, it's a very well made looking gizmo. Not trying to sell anyone on it or anything, just noting the build quality. |
12-12-2018, 07:33 PM | #7 |
got 3k on the oem chain and still have plenty of adjustment left. may change it at 10k just for shits and giggles.
12-12-2018, 07:33 PM | #8 |
Dig through one of member ARH's threads about his age-old chain treatment he does with any and all chains.
12-12-2018, 07:47 PM | #9 |
I figured it was covered, I'll see what i can find. Thank you for your input Timcosby & culcune.
12-12-2018, 07:51 PM | #10 | ||
Gearing/Ratios: To start, one thing needs to be considered with gearing changes and the various types of bikes out there. The rear tire diameter changes the effective overall ratio of the bike as it goes down the road. Example. A Hawk with the ubiquitous 17/45 combination on a stock 110/100-18 tire. To match the exact same effective gearing on a Storm with it's smaller diameter 110/90-17 rear tire would require 3 less teeth on the rear sprocket or a 17/42 combination. In fact, for the Storm and most of the other 17 inch wheel bikes a fairly consistent rule of thumb to compare gear ratios is to take off 3 teeth from the rear sprocket count of a Hawk. What I consider ideal? That really comes down to use of the bike - trail or street, weight of the rider and equipment, terrain (lots of big hills etc). If purely off road grunt is desired, the stock 15/50 of the Hawk is hard to beat. I have found the best 50/50 ratios to be around 17/47 give or take a tooth out back. The 17/45 is so popular because it makes the Hawk an effective road and off-road bike, but at this point it definitely favors the road just a bit more. My personal favorite for road and highway use is the 17/43. This gets the revs down in 5th gear, allowing the bike to cruise at 60mph with ease though it can struggle with bigger hills and strong head winds. Any lower than this is not likely a good idea for bigger guys or people that pack their bikes with lots of gear. You also lose a lot of the pep in the lower gears, making it not very good for trail use beyond your basic dirt path or back road. One trick myself and Jerry have both kind of taken to doing is finding a rear sprocket ratio paired with the largest front sprocket best suited for road use, and then if needed/desired swapping out the front sprocket to a lower count. Ex: I ran a 17/43 around town most of the time, but if I decided to go run a trail or have a bit of fun I would swap out the front for a 15 tooth, which gave me the same effective ratio as a 17/49. Front sprocket swaps are much easier to do compared to the rear, usually only taking about 10 minutes tops. I repeated this same trick with my 520 conversion, opting for a 13/35 (same as a 17/45), and I have a 12 tooth front sprocket, which when installed gives roughly the same basic ratio as said 17/49. Quote:
O-Ring vs. Non O-ring. I prefer O-rings. I have found them to generally survive longer than their counter parts in equal conditions. Others have found the opposite to be true. Are they worth the price difference? That is a matter of opinion. I think the key here is to not cheap out on your chain in either case. My top 3 brands = EK, RK, and DID. In either O ring or non. For a 428 chain setup 128 or 130 links. For a 520 chain setup, 100-104 links. If you shop around and look for good deals you can get a great O ring chain for about $60-70. Also sometimes deals in unlikely ways. Example; My 520 chain is a DID VX2 (X-ring chain) that I purchased for a mere $62. The catch was that I bought a 120 link chain, which because of supply and demand reasons was actually 15 dollars cheaper than the length I actually needed. All I had to do was shorten it. On my last Hawk, I ran an EK SROZ (O ring) 428 chain for about 3000 miles before I decided to convert it to a 520 chain. I ran that chain from day 1 mile 0, and it was still in perfect shape, and the sprockets were also barely showing signs of wear. Now, I should also issue a disclaimer. I am obsessive about maintenance, and this is no different with chains. I kept a 500 mile cleaning and lube schedule for road use, and I also would give my chain a quick spray of lubricant after riding in the wet the previous ride. If I used the bike off road, I would generally clean it at the end of that day. In the end, no matter what type of chain you use it comes down to how you care for it that can really determine how long it will last. A well cared for standard chain should last thousands of miles. O-ring chains are definitely much more forgiving to chain care negligence, which is likely one big reasons they are standard on most OEM bikes these days. As for the 520 chain swap...there is nothing inherently wrong with a 428 chain in these applications (Storms, Hawks, etc). It is my own opinion, and of a couple others, that the 428 chain is borderline on the weak side given the weight and intended use of these bikes. Look no further than the CRF230F, which isn't that much more powerful and close to the same weight, which comes from the factory with a 520 chain. Think of it like going from just strong enough to slightly overkill. Ok, I am done for now even though I could say more. My 2 cents turned into 2 bits.
12-12-2018, 08:12 PM | #11 |
I was hoping you would chime in and I got plenty... Well Dan you should know that most of what you said has been well thought through and I have came to the same conclusion. To me a a good strong chain should allow a quick switch of a front sprocket to allow a good commuter set up to something to tear up the trails while accounting for clearance for the front sprocket and chain. I set the chain price to cover a o-ring and venture in to a x-ring and see where it led too. You have satisfied my curiosity to the fact that i'm on the right track. Thank you once again!
12-12-2018, 08:26 PM | #12 | |
Honestly, if you add up the price difference between the sprockets and the chains, assuming you were changing both front and rear sprockets, you can upgrade to a 520 setup for just about the same price. Lets look at the 17/45 428 combination vs 13/35 520 both in O-ring. All prices currently on Amazon. 13/35: Front Sprocket JTF328.13 - $12 Rear Sprocket JTR279.35 - $20 DID 520 VX2 Chain - $70 (nice round number). Total: $102 17/45: Front Sprocket JTF259.17 - $11 Rear Sprocket JTR269.45 - $25 DID 428 VX2 Chain - $70 (literally the same price). Total: $106 Just food for thought if you are going to go to town and do both sprockets and a chain.
12-12-2018, 08:51 PM | #13 |
Thanks Dan and no thank you because I already have 428 sprockets, I guess I can go down the 428 road for now and save the 520 conversation for the future. I still need a really good go too chain that can handle a front sprocket switch with little stretch for a acceptable amount of time at a fair price! This has been very helpful.
Looks like the DID chains are a favorite in any ring type.
12-12-2018, 09:30 PM | #14 |
I don't think I've gone on a chain rant for a year or more. The chain that comes with the bike is an unknown quantity. It is either a junk quality chain on its way to the dumpster from the first day you go for a ride, or it's a so-so quality chain hampered by low quality lubrication. So two low cost solutions. The cheapest way to go is to clean the old lubricant out of the old chain with kerosene or gasoline, then, after it is dry, cook it in some kind of sticky grease, like CV joint grease, or in a bath of Gulf Canning Wax laced wit a healthy dose of colloidial graphite. That's what I've used for the last 50 years - wax with graphite. Another solution is to buy a higher quality chain, like Unibear 428 H chain, or similar from JV or others, and run it for a while. Then give it the same treatment...ARH P.S. Don't do this in the garage! Do the cooking and chain lubing away from the house and/or garage!!
12-12-2018, 09:38 PM | #15 | |
